Old 12-18-2019, 05:53 PM   #1
Manospeed
Default Mileage check-in...
Let's see how many of us are still running.
Year: 2007
Engine: 2.2 liter
Mileage: 149,000 miles
Mechanical Issues: None
Work done:
Timing chain, Coil pack/boots, ECM, spark plugs, struts, front brake pads, front wheel bearings, inner/outer tie rods, valve cover gasket, Rear drums + internal hardware, rear brake lines, crankshaft position sensor, transmission filter replacement, pan magnet replacement, transmission fluid replacement, water pump, thermostat, stabilizer bar links.
This vehicle has surprised me. Never in my life did I think it would still be running, but with a little investment in time/money we've managed to keep it going strong. Cosmetically, I need to get the cabin headliner repaired as its begun falling down from the windshield on back by about 2-3 inches. The rear wiper has stopped working as well, but otherwise I feel this vehicle still has plenty of life in it. Oil changes are full synthetic every 6,000 miles.
Way things are going, I believe subframe rust will be the reason this vehicle is retired and not anything to do with mechanical issues.
Add to Manospeed's Reputation
Rate the quality of this post and help Manospeed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-19-2019, 07:10 PM   #2
Bismarck318
Bismarck318 is on a distinguished road
Default Re: Mileage check-in...
Someone here gave me a neat trick for the headliner repair. Search the subject, just a simple stick of school glue & a credit card fixed it in a couple minutes.
Mine appears to eat a bearing every 10K aside of the undercarriage rust.
Add to Bismarck318's Reputation
Rate the quality of this post and help Bismarck318 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-20-2019, 12:46 PM   #3
Manospeed
If I'm not mistaken, I remember seeing a repair spray specifically to repair the headliner. Although I imagine a glue stick should do the trick.
Old 12-20-2019, 01:20 PM   #4
Bismarck318
Headliner Sagging
See post 5, this worked real well, use a credit card to flatten going forward toward the windshield, may have to wait till it is less humid out as it stretches back a bit.
Mine had been holding well for 2 years also... cost < $1.
Old 01-23-2020, 06:47 PM   #5
Bismarck318
Headliner Sagging
Better yet.....Headliner Drooping.
This worked great!
Old 01-24-2020, 07:03 AM   #6
Rob1956
Rob1956 is on a distinguished road
2003 VUE 2.2L
Year: 2003
Model: Vue, AWD, 4cy
Milage: 193,300
Had new CVT put in at 60,000, that failed at 90,000. Finally had a CVT not built in Hungry put in in 2013, still running strong. Have always babied the car, never accelerate past 3,000 rpm, wash every 2 weeks. Driver side carpeting dirty up in the well, will try some oxy cleaner. No rattles, except the fold down grocery carrier. Had a problem with turn signals being wonky after a rain, but that cleard itself up a couple of weeks ago after about 6 years of being wonky.
5th car since 1979, so I keep them for a long time.
Add to Rob1956's Reputation
Rate the quality of this post and help Rob1956 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rob1956 is offline   Reply With Quote
High mileage check-in hoody123 Astra General 10 09-02-2016 04:50 PM
Mileage check in Redline09 Ion General 5 07-07-2015 10:59 PM
Mileage Check-In Part III AuraDrvr89 Aura General 28 08-25-2010 12:55 PM
Mileage Check-In! AuraDrvr89 Aura General 41 09-16-2008 12:42 AM
Mileage Check! silverblueL200 L-Series General 1 04-27-2004 11:57 PM
