Old 11-10-2019, 12:39 PM   #1
sc2dave
sc2dave is on a distinguished road
sc2dave's Avatar
Default Need screw in fitting for water heater hose, dr. side
'96 sc2. I need the heater hose fitting that goes on the intake manifold on the driver side, Anyone have a listing for it on Ebay or Amazon, maybe auto parts store? thanks.
www.bold-fortune.com
Add to sc2dave's Reputation
Rate the quality of this post and help sc2dave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2dave is offline   Reply With Quote
Old 11-10-2019, 02:01 PM   #2
Default Re: Need screw in fitting for water heater hose, dr. side
Got it out, can you post a picture? I'm guessing it is NPT and you can get a suitable one from even Lowes or Home Depot. At your FLAPS, Dorman is a common brand, look on the Dorman web-site for a match.
Add to billr's Reputation
Old 11-10-2019, 03:26 PM   #3
sc2dave
sc2dave's Avatar
Originally Posted by billr View Post
Got it out, can you post a picture? .
Ihaven't put a wrench to it, but I'm thinking that it might break off in the manifold. The part that connects to the hose just broke off with finger pressure.
Old 11-30-2019, 05:25 PM   #4
sc2dave
sc2dave's Avatar
anyone have a picture of this?
Old 11-30-2019, 07:16 PM   #5
Is this the intake manifold with heater outlet? If yes, there are threads about it. One video, https://www.youtube.com/watch?v=jtiv4FTcPg4, shows a repair. Other videos are available. Dorman part, https://www.amazon.com/Dorman-902-10...12713976&psc=1.
Old 12-01-2019, 12:03 AM   #6
That's for the craptastic 3rd gen plastic intake manifold. The aluminum intake manifolds have a screw in fitting "hose barb" that threads into the IM while providing a nipple for the coolant hose to slip onto.
I've no idea what the thread is, but I'd hazard a guess that the hose is 5/8" so you'd need a 5/8" barb and try a couple different 5/8" thread styles to see what fits in the intake. Pipe thread tends to be a narrow measure for a given size while straight/compression thread tends to be normal/wide measure.
Old 11-10-2019, 02:21 PM   #7
Seems like an odd part to fail, which may make it hard to find. It is probably a pipe thread. If you can measure the old one, would be easier to find a replacement. Or grab one from a junkyard. Will probably be free.
Add to Waiex191's Reputation
PCV breather hose fitting Claybury S-Series Tech 0 11-01-2016 03:35 PM
3.5L tee fitting for coolant hose RobertGary1 Vue Tech 0 01-13-2016 02:34 PM
'97 SC2 heater hose removal for heater core flush SC2by2 S-Series General 3 10-24-2015 07:03 PM
Cracked fitting-end of overflow hose SL2Many S-Series Tech 4 05-17-2011 09:43 PM
brass fitting near oil cap on valve cover, where does hose go? mikes 1994 z28 S-Series General 1 08-05-2006 02:06 PM
