Old 09-21-2019, 04:38 PM   #1
2teendaughters
2teendaughters is on a distinguished road
2teendaughters's Avatar
Default Right side head lights dim.
When lights are turned on the right side is very dim. Both high and low beam. When switched between high and low the opposite seems to happen. Getting 12vdc and as near as I can tell the ground is intact. Has the headlight switch taken a dump? or is there another possible check I can look into.
Craig
2000 Sl2 (1st Daughter 2nd Sl2)
2001 Sl2 (Wifes)
2002 Sl2 (2nd Daughter)
2000 Sl2 (RIP Wrecked by 1st Daughter Sold)
2001 Sl2 (1/2 a car bought for Parts Sold)
Add to 2teendaughters's Reputation
Rate the quality of this post and help 2teendaughters reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2teendaughters is offline   Reply With Quote
Old 09-21-2019, 05:05 PM   #2
Default Re: Right side head lights dim.
Which car?
Old 09-21-2019, 05:17 PM   #3
2teendaughters
Sorry 2001 sl2
Craig
2001 Sl2 (Wifes)
Old 09-21-2019, 05:35 PM   #4
I'm not near service manuals for posting and going on memory but if I'm not mistaken, there are two wiring schematics, one for manually turning on headlights and the daytime running lights using a complicated wiring scheme. The drl circuit may affect manual lighting but not the other way. Drl uses a relay downstream from fuse(s), controlled by the bcm. Check all headlight fuses for looseness, drl relay and wiring in general. I'm not sure if your '01 SL2 uses parking or high beams for daytime running lights and complicates where to check. Some GM drl circuits use a combination of serial and parallel wiring along with adding a resistor in other drl circuits.
If this problem exists only in drl or manual lighting mode, the problem can be narrowed down. There may be wiring diagrams posted in other threads and you can use circuits from 2000 and up.
Old 09-21-2019, 06:43 PM   #5
2teendaughters
Fuses checked and relay replaced. These were my first thoughts. Only the right side is affected. Haven't seen a wire schematic. Wondering if circuit is split Left and Right in the headlight switch? There isn't any indication in the (PDM) power distribution module. Stumped non the less.
Craig
2001 Sl2 (Wifes)
Old 09-21-2019, 07:22 PM   #6
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: Right side head lights dim.
Does this help
1995 SL1 236,300 2005>2018
1997 SL1 78,100 2014>????
CHECK YOUR OIL!!
Add to SRGW's Reputation
Can I patch tail lights into head lights? mgordon1100 S-Series Tech 1 05-01-2010 05:48 PM
WTB drivers side head light bracket for 03 VUE jhutch2115 Classifieds 0 07-27-2006 09:36 PM
wtb 3rd gen head lights sc mad_nigerian Classifieds 0 03-14-2006 01:51 PM
Cargo Cover With Side Head Curtain Air Bags on '04? Black-N-Tan Vue General 12 01-27-2004 08:20 PM
Help, dim head lights Son93SL2 S-Series Tech 10 02-09-2001 11:42 PM
