Old 07-09-2016, 12:47 PM   #1
carvinbassplyr
carvinbassplyr is on a distinguished road
2005 VUE Red Line
Default HELP!!! Trailing Arm Bracket Bolt Top Access Point Needed
Trying to remove the trailing arm front bracket bolts and one of the tack welded nuts that the bolt threads into broke free from the car. So, now the bolt just spins freely and won't come the rest of the way out. Has anyone ever had to fix this and do you know of any access points? Obviously now the car isn't exactly driveable even if I put the rest back together as the bracket will be loose. Feeling really screwed...
Add to carvinbassplyr's Reputation
Rate the quality of this post and help carvinbassplyr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carvinbassplyr is offline   Reply With Quote
Old 07-09-2016, 01:59 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: HELP!!! Trailing Arm Bracket Bolt Top Access Point Needed
Not 100% certain my diagram applies - if it does it appears there's room to cut a slot for open-end wrench.
Old 07-09-2016, 02:23 PM   #3
carvinbassplyr
2005 VUE Red Line
THANK YOU FOR THIS!!! Exploring that option now!
Old 07-09-2016, 03:46 PM   #4
carvinbassplyr
2005 VUE Red Line
Turns out it's a square nut in a box bracket design. Still having a hard time getting to whatever is slipping because of the box caged around the nut, keeping at it though. GM obviously expected people to just junk the car if this part went bad, this seems designed to never be serviced. Hopefully i can get it fixed
Old 12-29-2019, 05:22 AM   #5
hoffnm
hoffnm is on a distinguished road
I had the same issue where the bolt turned but the nut was spinning on the back side. far2grumpy's image is what I went with...I cut a hole (to fit a plug I had), bottom of the hole was 1-1/4" from bottom (marking on bolt for nut engagement). See pics. I was able to get inside with a slip joint pliers and hold the nut after spraying with penetrating oil. First I tightened it back up holding it, then sprayed again, then loosened and it came right off. Their is a cage tacked welded in 3 places, this is supposed to hold the nut plate from turning. Mine was already broke free, if yours is spinning inside the cage, a punch/hammer should knock it loose so you can hold the nut plate. The nut plate is rectangle and measures 15/16" on one side and 1-3/8" on the other side. Bigger the hole the better the access.
Add to hoffnm's Reputation
Rate the quality of this post and help hoffnm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoffnm is offline   Reply With Quote
missing bolt (metric or SAE?) for PS bracket VUEmaniac S-Series Tech 7 08-06-2014 11:20 AM
SW2 Trailing Arm - Bolt Size ? SalemCat S-Series Tech 19 07-11-2012 04:57 PM
So my rear trailing arm broke...{stuck bolt question} cmjj42 S-Series Tech 8 10-17-2011 01:37 AM
Knuckle makes angle with trailing-arm-attachment point? bertwhitaker S-Series Tech 0 08-10-2011 10:00 AM
'02 Fuel Filter Bracket Bolt MiSaturn S-Series Tech 2 10-13-2007 09:29 AM
