Old 09-30-2013, 12:21 AM   #1
takkun_2000
takkun_2000 has a spectacular aura abouttakkun_2000 has a spectacular aura about
takkun_2000's Avatar
2000 SL1
Default suspension
hey guys i was wondering im looking for a nice suspension set up after market because i am looking at taking my saturn sl1 to a track day i was wondering if you had any suggestions on things that have worked for you... i would like something that i can lower my car and is a bit stiffer... my 100% dream would be for a fully adjustable to where i can change toe and camber as well as ride hight and stiffness... however this is just a dream because i am just a poor college kid so cost is a bit of a problem
Add to takkun_2000's Reputation
Rate the quality of this post and help takkun_2000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
takkun_2000 is offline   Reply With Quote
Old 09-30-2013, 01:17 AM   #2
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Default Re: suspension
First, an SL2's suspension is setup stiffer. You could find the rollbars off of an S(L,C,W)2 and install them on your SL1.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 09-30-2013, 05:45 AM   #3
Quite a few "auto-x"er's like the SL1 front sway bar while adding a rear sway bar idea.
H&R Sport Springs = ~$210
GR-2 Struts = ~$200 for all 4
Front strut mounts = ~$100
Reuse the rear strut mounts and all bellows & bump stops.
4 wheel Alignment = ~$80, preference seems to be between -1.5 and -2 camber on the front, -1 camber on the rear and zero toe in/out. Factory specs will work fine as well, these will just enhance cornering ability a bit...as well as adding a bit of inside tire wear to the front.
Old 10-01-2013, 12:38 AM   #4
takkun_2000
2000 SL1
thank you very much for the help... my setup that i want is -2 camber and -.125 toe for the fronts
Old 10-01-2013, 02:10 PM   #5
sallydriver
1993 SW2
Fetchitfido, is that preferred so the car rotates more easily? I'm wanting to get in the autocross scene (among others) once I can get a second Saturn
Old 10-01-2013, 04:08 PM   #6
I'm not sure exactly why but I assume it allows a bit more weight transfer to the front or helps keep all 4 wheels on the ground during hard cornering. Been mentioned quite a few times in the past.
Old 11-07-2013, 10:16 AM   #7
proveniebam
proveniebam is a jewel in the roughproveniebam is a jewel in the roughproveniebam is a jewel in the rough
Out of the box the saturn has limited camber adjustment. -2 camber will involve either a new strut mounting bracket or drilling of the strut/knuckle joint.
Add to proveniebam's Reputation
Rate the quality of this post and help proveniebam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proveniebam is offline   Reply With Quote
suspension 05BlueVueRL Vue Red Line 4 10-21-2011 04:12 PM
s l o w l y getting my suspension done twosaturns Vue Mods 8 07-29-2008 10:30 PM
first gen suspension saturnbomb S-Series Mods 10 11-13-2006 11:34 AM
Two recall notices - RDM & suspension, then suspension - Anyone else? John223 Vue General 4 03-09-2005 07:27 PM
Suspension LW2cool L-Series General 5 11-07-2003 12:11 PM
