Old 08-01-2013, 08:23 AM   #1
brice017
brice017 is on a distinguished road
Default buying astra: carfax shows engine wiring repaired/alternator replaced. Why???
Was about to purchase an Astra from dealer, when I pulled the Carfax.
1/2012 maintenance inspection completed:
battery/charging system checked
alternator/generator replaced
No dealer service on carfax since.
Not knowing much about these cars, is this a common issue?
Should I avoid this car?
It's a great deal. I was going to purchase and have it shipped to me, as similar cars are 4K+ higher in the mid-atlantic.
Any insight would be much appriciated.
Add to brice017's Reputation
Rate the quality of this post and help brice017 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brice017 is offline   Reply With Quote
Old 08-02-2013, 03:03 AM   #2
smwalker
smwalker has a spectacular aura aboutsmwalker has a spectacular aura aboutsmwalker has a spectacular aura about
2008 Astra XR
Default Re: buying astra: carfax shows engine wiring repaired/alternator replaced. Why???
Hey brice. Have not heard of wiring problems that are common. With the alternators there was a chirping with the AC on. Soloution was to replace the pulley. But it needed a special tool that none if the gm dealers had so they ended up replacing the whole alternator in some cases.
Could be that, maybe.
Get on yelp.com and find a well reviewed mechanic near the seller and have them take it over there for an inspection. Cost you 100, but could save you thousands.
Good luck!
Add to smwalker's Reputation
Rate the quality of this post and help smwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smwalker is offline   Reply With Quote
Old 08-02-2013, 04:13 PM   #3
Astra La Vista!
Astra La Vista! has a spectacular aura aboutAstra La Vista! has a spectacular aura about
Astra La Vista!'s Avatar
2008 Astra XR
Alternator may have short circuited internally, damaging it and the surrounding wiring.
Mid-atlantic? As in, the Azores? Might want to ask on the European forums if this is the case.
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
Add to Astra La Vista!'s Reputation
Rate the quality of this post and help Astra La Vista! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra La Vista! is offline   Reply With Quote
2002 Sc2 Alternator Repaired, Still having Problems FrenchChoc S-Series General 7 10-03-2012 09:00 AM
Clutch repaired and replaced, now still have a knocking noise Crzesk8dad S-Series Tech 9 01-04-2012 03:17 AM
Astra Shows that Change is Good for Saturn Charlie Astra General 0 08-31-2008 11:29 PM
Buying a 99 SL2 in 3 hours. I did an AutoCheck but would like a Carfax if anyone can? 2002SaturnMan S-Series General 1 04-18-2006 05:08 PM
Anyone had racks and chips in their glass repaired rather than replaced? Blue Goose Vue General 9 09-01-2004 12:24 PM
