Old 11-24-2012, 11:21 PM   #1
hoffman_BMX89
hoffman_BMX89 is on a distinguished road
hoffman_BMX89's Avatar
Default changed thermostat now i got no heat HELP!
hey guys i am hoping someone here can help me with my dilema btw the car is a 2005 vue 2.2l 5spd. So i had to change my thermostat due to a pesky p0128 cel. While i was down there i also replaced my ects sensor. When i pulled the thermostat the seal on the inside was all chewed up so i guess it wanst closing all the way which was causing the cel. I got a brand new acdelco thermostat and ects from rock auto. So i changed both parts fill up the coolant and bleed it but now i got no heat, and my car is running weird the temp gauge goes from 1/4-3/4 it never did this before usually it would stay just a touch over 1/4. When i touch the hoses from the heater core only the bottom one is hot the top one is cool to touch. but when i shut off the car the top one gets hotonce all the coolant settles. When i start up again i have heat for a brief minute. What could i have done wrong here guys i am almost thinking that i put the thermostat in wrong but from what i remember it can only go in one way. and i really dont want to take that thing apart again it was a pain in the as*
1997 Sl2 447000km sold
1998 Sl2 278000km sold
2005 Vue 178000km current car
Add to hoffman_BMX89's Reputation
Rate the quality of this post and help hoffman_BMX89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoffman_BMX89 is offline   Reply With Quote
Old 11-25-2012, 12:01 AM   #2
ssicarman
ssicarman's Avatar
Default Re: changed thermostat now i got no heat HELP!
The heater core is likely air locked. Try bleeding the air from it. The colder hose is the one you want to work with. On the engine side (engine off, rad cap off) slide the clamp down the hose and loosen the hose from the fitting but leave it in place. Start the car and use a smaller screw driver to create a gap between the hose and the fitting. This will let the air out and should let the coolant flow through the heater core. When you start to get coolant coming out of the opening remove the screw driver and see if you start to get heat. You will likely need to do it a few times and maybe even on the the other hose.
Add to ssicarman's Reputation
Old 11-25-2012, 05:39 PM   #3
Double GG
Double GG is on a distinguished road
Double GG's Avatar
Agreed. A good practice that I've done when refilling an engine is to dump the coolant into the radiator and engine separately and bump the truck around to dislodge some of the air bubbles. Drive it around a bit and watch the temps and eventually the system will burp itself.
Add to Double GG's Reputation
Rate the quality of this post and help Double GG reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Double GG is offline   Reply With Quote
Old 11-25-2012, 06:30 PM   #4
hoffman_BMX89
Thanks for the input guys I have tried all of this and still no heat. I would get a bit of heat at the beginning and then nothing. The temp gauge is all over the place too I will be at 1/2 then all of a sudden to below 1/4 I have decided to take the thermostat out and replace it again I think it's faulty. Let me know what you guys think.
Old 11-25-2012, 07:29 PM   #5
far2grumpy
far2grumpy's Avatar
To best of my knowledge each engine with water pump requires a coolant bypass system to circulate coolant when the thermostat is closed.
The 3.5 engine uses the heater core and throttle body de-icer for the bypass.
I suspect the 2.2 does likewise. So, the question is - could the heater core be clogged?
There are probably coolant hoses leading to throttle body - check these for heated coolant soon after engine start.
No flow to either and the wildly swinging ECT could indicate air blockage downstream of thermostat - bad thermostat - bad water pump, etc.
Old 11-25-2012, 07:46 PM   #6
hoffman_BMX89
i flushed the heater core alreday by unhooking it and running the hose through it it was clear. all hoses are hot when the car is on except the ones to the heater core they seem to only be hot when they want to
Old 02-21-2013, 05:11 PM   #7
supercars
supercars is on a distinguished road
Check that thermostat installed correctly. There is a black plastic spacer that holds thermostat between heater core lines. This allows spring to face water pump. Which is correct position in 04 Vue 2.2. If spring is facing block and both heater core lines are behind it you have installed it wrong. Hope this helps we just solved same problem on a Vue.
Add to supercars's Reputation
Rate the quality of this post and help supercars reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
supercars is offline   Reply With Quote
Old 12-30-2013, 10:17 AM   #8
02BlackSC2
02BlackSC2 is on a distinguished road
2005 VUE Red Line
I know it has been a while, but anyone know how this turned out?
Add to 02BlackSC2's Reputation
Rate the quality of this post and help 02BlackSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02BlackSC2 is offline   Reply With Quote
Old 12-14-2014, 10:37 PM   #9
David 93 SL2m
David 93 SL2m's Avatar
2007 ION-3 Sedan
Happy Re: changed thermostat now i got no heat HELP!
I changed the thermostat on my 2004 VUE with the Ecotec 2.2 liter engine and had the same exact outcome as hoffman_BMX89.
supercars is correct. The incorrect re-assembly of the thermostat and the associated components will lead to the issues described in this thread.
Now that I see how to do this correctly, I get the joy of doing this rather difficult job again.
The following images show the correct re-assembly.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline   Reply With Quote
No heat..thermostat question slimgoodie_5 S-Series Tech 4 01-05-2010 11:14 AM
changed my thermostat and... S3aturnR S-Series Tech 9 12-17-2009 04:09 PM
Changed thermostat twice, still no hear in car Driver23 S-Series Tech 4 08-12-2009 07:19 PM
Changed thermostat twice-car doesn't get heat Driver23 S-Series Tech 4 12-18-2008 05:55 PM
Question about heat and thermostat Spazie S-Series General 8 03-01-2005 05:35 AM
