Old 08-19-2010, 04:19 PM   #1
kris V
kris V is on a distinguished road
Dizzy 99 sc2 rear quarter glass
Does anyone know how to remove the rear passenger quarter glass on a 99 sc2 my was broken when i walked out this morning, I took the trim off and doesn't seem to be screwed on it only has a riveted thing on one corner.Thanks in advance
kris V is offline   Reply With Quote
Old 08-19-2010, 06:37 PM   #2
Default Re: 99 sc2 rear quarter glass
If it's like my '96 then you "just" need a reciprocating saw & flat stiff plastic paddle (like a putty knife but plastic), instead of the normal saw blade. That's all the glass guy used to remove it from my '95 SC1 parts car to put on my '96 SC2.
Old 08-19-2010, 06:47 PM   #3
kris V
thank u so much so what you're saying is just stick the putty knife in between the glass and car and pull it off
Old 08-19-2010, 06:53 PM   #4
That's all the guy did, though I'd imagine a metal putty knife would be apt to scratch the crud out of the glass.
He went from the inside of the car, and ran the sawzall all around the window cutting the "glue" roughly in half. Not sure what he used to clean the "glue" completely off the glass, but he had it all off before putting new "glue" on the car, then set the glass in place and pressed it in.
Looked like a really simple procedure that the lack of info on here makes seem ridiculously complicated.
New rear quarter glass in my case would have been $230 (windshield for '97 SC1 from same company was $180) but they were able to swap it for $100.
Old 06-18-2019, 07:36 PM   #5
spettro9
spettro9 is on a distinguished road
spettro9's Avatar
2001 SC1
Why the h*ll is this piece made of glass?
I've been trying for years to figure out how to get it off, and now there's a leak behind there, I have to.
2001 Silver SC1, from craigslist in Clifton, NJ 2011/01/21, with 70k miles, $3K,
27 normal (winter 25 mpg) / 37-40 highway
(just have to watch oil a bit... seems to be 3/4 qt in 1000 miles, )
spettro9 is offline   Reply With Quote
Old 06-19-2019, 12:52 AM   #6
spettro9
spettro9's Avatar
2001 SC1
I'm going to add my observations with the rear quarter glass on my 2001 SC1
I had been hunting a little leak for a while now, and was determined to get the door molding off, but could never see how to get that quarter panel off.
I didn't even know it was glass.
I pried up a bit with a flat bar to see how it was put on and I broke it.
I cleaned up the glass (involving taking quarter panel fender off..)
It's pretty much put on with a thick consistent bead of caulk/adhesive or similar from the factory. The bead goes along about 2" inside the edge all the way around.
There's 2 more rectangles of caulk/adhesive inside that bead, towards the front.
I would NOT want to try using a sawzall. The only way I could see is a long flexible (sharp) blade... going all the way around.
If you see the cones from the inside (one blue, black, and white) they are just there to help with locating it when installing; they are not fasteners of any kind.
Tags
glass, quarter, rear, replacement, trim
installing a quarter glass window fusion61 S-Series Tech 2 10-18-2007 06:03 PM
noise in rear quarter vintagegz Vue Tech 0 05-25-2007 07:31 AM
WTB: 2000 Saturn sc2 Rear bumper and rear driver side quarter panel vextc05 S-Series General 2 11-06-2006 02:17 PM
Rear quarter window (help) patcal S-Series General 0 11-05-2005 11:08 AM
WTB: 92-95 SL left rear quarter panel bryan_johnson Classifieds 3 04-12-2005 05:13 AM
