Old 05-26-2010, 11:57 AM   #1
cousinsaul
cousinsaul is on a distinguished road
cousinsaul's Avatar
Default exterior door trim
I'm exactly sure which forum to post this in but here it goes. one of the black trim pieces that goes on the outside B-pillar broke off and the finish on the others is badly worn. I've been looking online and haven't really found anything. Even getsaturnparts.net doesn't list them. Does anyone know where I can find a decent set? The closest junk yard to me is Hunts Point in NYC but I'm short on time and can't get down there. Any help would be much appreciated. I don't want my Saturn to look junky.
-Saul
Add to cousinsaul's Reputation
Rate the quality of this post and help cousinsaul reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cousinsaul is offline   Reply With Quote
Old 05-26-2010, 03:06 PM   #2
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Default Re: exterior door trim
Have replaced both B pillar trim pieces on both sides of my '02. Dealer charges around $20 each, from what I recall.
Once the finish starts to fail, you really have no other option than to repaint them to give them a uniform look again. You should be able to find a replacement for a couple of bucks at a boneyard, and with a $5 investment in paint, will be able to recoat all 4 pieces.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 06-27-2010, 02:45 PM   #3
cschmidt
cschmidt will become famous soon enoughcschmidt will become famous soon enough
MiSaturn,
Is this the piece that your replaced for $20? See pix - I am talking about the black vertical strip (that has the paint coming off at the bottom, maybe 2" wide).
I was about to try and repaint both sides on my daughter's car. For $20 I would prefer to get new ones. How do they come off? I saw what looks like a torx bolt at the base you can access from the inside door jam.
Thanks,
Chuck
Add to cschmidt's Reputation
Rate the quality of this post and help cschmidt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cschmidt is offline   Reply With Quote
Old 06-27-2010, 02:54 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
getsaturnparts sells them.
Heres the fronts for $19.62, #4 in the illustration:
http://www.trademotion.com/partlocat...layCatalogid=0
And the rear for $19.62, #4 in the illustration:
Removal:
1- Remove two retaining screws
2- Slide applique rearward to disengage hooks from door.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 06-27-2010, 02:55 PM   #5
cschmidt
Searched a bit longer and found an answer - see link . Then saw the reply inbetween by Mike - thanks for the quick response. This forum is great!
I'll check my '98 to see if it is rivets or tabs.
Chuck
http://www.saturnfans.com/forums/sho...rior+door+trim
Old 06-27-2010, 02:57 PM   #6
PurdueGuy
PurdueGuy's Avatar
1999 SC1
What year/model are we talking about here? It says you have a 99 SL2 under your name, is that what this is on? Always good to be sure.
If it is on the '99 SL2, then you can just remove a couple screws & remove that trim piece. Then you just have to decide between trying to track down brand new parts or getting junkyard parts.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 06-27-2010, 03:00 PM   #7
Low Saturn
Low Saturn's Avatar
2000 SC2
Coupes use rivets, sedans/wagons use screws.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 06-27-2010, 03:20 PM   #8
cschmidt
It's a '98 SC2.... I think that is what is under my name. Time to find my glasses. 8-) OK I looked back and it is the original poster that has the 99 SL.
Again Mike is quick on the draw, so coupes have rivets. Thanks! Also the Coupe parts are $41... I'll look at them again and may just repaint.
Chuck
Old 06-18-2019, 07:37 PM   #9
spettro9
spettro9 is on a distinguished road
spettro9's Avatar
2001 SC1
For anyone looking for info about Coupes/SC1/SC2
Look here:
http://www.saturnfans.com/forums/sho...d.php?t=157717
Didn't even know what to call this part or that it was made of glass until now...
2001 Silver SC1, from craigslist in Clifton, NJ 2011/01/21, with 70k miles, $3K,
27 normal (winter 25 mpg) / 37-40 highway
(just have to watch oil a bit... seems to be 3/4 qt in 1000 miles, )
Add to spettro9's Reputation
Rate the quality of this post and help spettro9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spettro9 is offline   Reply With Quote
Relay ,Exterior Trim, and blindspots. seanc516 Relay General 4 11-13-2007 12:30 AM
Exterior window trim is scratched up, suggestions? donedds S-Series General 3 02-18-2006 09:44 PM
Help getting the exterior door handle off! number9 S-Series General 5 01-01-2006 07:44 PM
Cleaning exterior plastic trim silverblueL200 L-Series General 1 05-20-2003 10:40 PM
FS: Exterior Door Panels SIextreme Classifieds 0 05-15-2003 09:13 PM
