Old 06-09-2019, 08:39 PM   #1
nealt
nealt is on a distinguished road
nealt's Avatar
1997 SC2
1999 SC2
Default Radio Dimmer Wiring
I have a 97 SC2, and the LCD dimmer back light is not working when the parking/headlights are on. The buttons are being illuminated however, just not the LCD for the time and station. Very hard to read the time at night.
Does anyone know what color of wires and the corresponding wire number that controls the illumination? On the wiring harness, they are numbered 1-20.
Also, if the illumination wires are separate, can I just splice into the other good working wire to get the LCD backlight to work?
Add to nealt's Reputation
Rate the quality of this post and help nealt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nealt is offline   Reply With Quote
Old 06-09-2019, 09:01 PM   #2
nealt
nealt's Avatar
1997 SC2
1999 SC2
Default Re: Radio Dimmer Wiring
And I did try a different radio and it had the same problem, so I'm pretty sure it's not the radio...
Old 06-09-2019, 11:32 PM   #3
Attached. Says '89-'90 and newer because it's the same wiring scheme used on every single GM of the 90's (the "missing" slot is for the optional CD changer and mostly unused so it's blank on this one).
The 2 yellow wires are generally different gauge's, the smaller is for the speaker while the larger is for power.
File Type: jpg 1991 - 1999 S-Series Stereo Wire Guide.jpg (136.3 KB, 5 views)
Old 06-10-2019, 08:26 AM   #4
TomM96
>the LCD dimmer back light is not working when the parking/headlights are on. The buttons are being illuminated however,....
I think problem is burnt-out incandescent bulbs (for LCD backlight)
I think the issue becomes widespread after 20+ years, probably because those bulbs are subject to a hotter environment(under LCD, rather than on-board with ventilation surrounding)...
Richpin has video of replacement radio lights for Gen2; following some relevant threads {this a current issue for my 2000, thus my search skewed to Gen3}:
Saturn SL1 Radio and bulbs 1999 http://www.saturnfans.com/forums/sho...d.php?t=230579
2001 Saturn S Radio has no back light http://www.saturnfans.com/forums/sho...d.php?t=172065
97 SL backlight http://www.saturnfans.com/forums/sho...d.php?t=110493
Add to TomM96's Reputation
Old 06-10-2019, 08:47 AM   #5
nealt
nealt's Avatar
1997 SC2
1999 SC2
I find it odd that another radio I just got from a JY has the same problem.
From looking at the wires on the radio harness (not on the car), the colors do not match up with the wiring diagram provided.
Perhaps that wiring diagram does not apply to a 97? I'm hopping there is another dimmer wire.
On my radio wires, the harness pin out is as follows:
pin 1 - brown
pin 2 - green
pin 3 - gray
pin 4 - blue
pin 5 - blank
pin 6 - yellow
pin 7 - purple
pin 8 - empty
pin 9 - red/orange
pin 10 - orange/yellow
pin 11 to 16 - empty
pin 17 - brown
pin 18 - green
pin 19 - gray
pin 20 - blue
Old 06-10-2019, 09:36 AM   #6
The diagram is correct, someone replaced the harness in your car with an aftermarket one using custom colors.
Even when I put a '94 radio in a '97 everything except the dimmer worked as expected, GM changed the polarity of the dimmer between '95 and '96 so "max" became "min" and when I had the '97's dimmer set to min the gauge's and HVAC went dim but the radio went full bright (tried to blame the radio, put it back in the '94...dimmer worked properly).
Old 06-10-2019, 09:56 AM   #7
nealt
nealt's Avatar
1997 SC2
1999 SC2
This is the stock radio that came with the car. I have never changed it. And I bought the car new.
Old 06-10-2019, 10:51 AM   #8
Pins for lighting from the FSM:
6 - Brown - lights on
7 - Dark Green - dimmer
I've used that diagram for everything from a '89 Cutless Supreme to a '01 Silverado 2500HD, including 3 '97 SC's (and 10+ other '93-'97 S-Series).
Old 06-27-2019, 10:51 PM   #9
nealt
nealt's Avatar
1997 SC2
1999 SC2
Yes, the bulbs ended up being the problem. The bulbs were burnt out in both radios. I resoldered in a new bulb, and now both radios work properly.
The wiring diagram was correct too.
Thanks
dimmer switch for dash lights- wiring diagram RKelly5327 S-Series Tech 4 09-05-2018 09:19 AM
instrument dimmer and radio not working npereza5 L-Series General 17 06-02-2014 04:26 PM
Radio, dimmer, rear defogger stopped working kyager S-Series Tech 11 03-19-2013 03:43 PM
dimmer knob wiring and bulb brightness Sidneyaks S-Series Tech 5 09-03-2011 08:53 AM
wiring to dimmer switch the_skin_eater Mods and Performance 0 01-10-2005 01:09 PM
