Old 06-16-2019, 11:39 AM   #1
Trinity5
Trinity5 is on a distinguished road
Default Low RPM, moves slowly to get up to speed. Cat??
1997 Saturn SW2. Car was running like a champ, then the other day I was driving highway speed of 70mph and saw all my gauges go to the left and then they would come back and then back down. I have figured out that I need to replace the alternator. That being said....... the car also started to struggle to get up to speed from a stop and lower speeds. It was almost like the car was staying in low gear. I pulled over and the car wouldn't start at all.
AAA towed me home Before they did they used the battery charge unit and the car started right up but showed very low charge on the unit. (reason I bought a new Alt.)
I was thinking it could be a clogged cat. Any thoughts ??
This car has over 250K miles on it and last year I did replace the muffler from the Cat back because it was totally rusted.
I was thinking of going old school on it and removing the innards of the cat until I can get a replacement. I already passed inspection.
Thank You
Add to Trinity5's Reputation
Rate the quality of this post and help Trinity5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Trinity5 is offline   Reply With Quote
Old 06-16-2019, 12:20 PM   #2
Default Re: Low RPM, moves slowly to get up to speed. Cat??
The automatic can't work as intended if the alternator, battery and battery cables are not in proper working order. Get those working properly, do another test drive and then maybe worry about the exhaust.
Old 06-16-2019, 02:01 PM   #3
Trinity5
Thank you. My plan is to change the alternator out and see what the outcome is. I pray that it fixes my issue. I'm hoping to have ti changed out by next weekend. I will post results.
Thanks for your help.
Old 06-22-2019, 05:38 PM   #4
Trinity5
Changed out the alternator today and Saturn is back running like a champ.
Thanks for the help.
5 speed moves while off and in gear? Dman12ny S-Series Tech 3 09-10-2017 09:00 AM
sl2 02 at only moves first gear chufford02sl2 S-Series Tech 7 11-20-2014 10:19 AM
2004 Saturn Ion 2 QC 2.2 manual - revs slowly, returns slowly to idle chetterhead Ion Tech 14 09-22-2012 11:43 PM
gas meter moves??? trevino1 S-Series Tech 3 10-23-2008 02:41 PM
95 SC1, 5 speed manual, Shifter came loose (moves freely), Cant shift! JasonRW S-Series Tech 8 05-24-2008 11:06 AM
