Old 05-28-2018, 08:26 PM   #1
atikovi
Default Any write-up on radiator replacement for a Redline?
Was under my 2005 RL replacing the a/c compressor control valve when I noticed coolant dripping from the radiator at the right side tank. It was pretty high up so couldn't see the actual spot it was leaking from but would need the same steps to access it as to remove it. Does the bumper cover come off? A/C condenser?
Old 05-29-2018, 02:11 AM   #2
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
Default Re: Any write-up on radiator replacement for a Redline?
If it’s like the regular Vue you remove part of the front facia. Ac condenser doesn’t need to move.
-Robert
Radiator drain/replacement and Thermostat Replacement jeanne17 S-Series General 8 05-18-2010 08:48 PM
radiator transmission tube (manual; radiator replacement) sw87 S-Series Tech 3 03-27-2010 09:15 PM
Fuel pump replacement write up ? 98SlammedSL2 S-Series Tech 7 11-12-2008 10:24 PM
Clutch replacement write up??? STLWACO S-Series Tech 3 11-22-2006 11:46 PM
Timing Chain Replacement- Is there a write up with pics anywhere? gophaster S-Series General 2 04-29-2005 10:31 AM
