#1 |
![]() Join Date: Mar 2014
2001 Saturn SC2 -automatic door locking problem. I just installed a new driver side door lock switch, since the original broke. Now the car thinks the door is not closed. I know this because when the door is closed, with key in ignition, I click the lock button on the lock switch, and it locks then automatically unlocks (originally, it would do this when the door is open). When the door is closed, and the key is *Not in the ignition, the lock button works. Therefore, i believe the car thinks the door is open. Also, the lock button on the key fob does not lock it in any situation now. When I press the lock on the key fob, the horn honks three times. But the unlock on the key fob works.
I did unhook the battery when I was trouble shooting the broken lock switch. Is it possible that I disabled the car alarm? Or that when I installed the new switch, that I messed some door sensor? |
#2 |
or does anyone know how the car can sense that its doors are closed?
maybe that can point me in the right direction ![]() |
#3 | |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2010
![]() Quote:
Maybe a coincidence, but I am also working on an '01 SC2 for my daughter, and the RKE is acting odd. I have not done much with the car yet, but from memory, your symtoms sound very famailar. I was assuming I had a bad Key fob, but have not had a chance to dig into it. These cars have the RKE programmed by a dealer via Tech2 device (or so i am told). I don't think there are any settings for us to change DIY.
Mark '05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert. |
#4 | |
![]() Quote:
Check the dome light operation. Can be time consuming with a 4dr as there's a 20-30 second delay from door-close to light-off, but the "door open" sensor is the same for the locks and the dome light. The door that doesn't turn on the light has a problem in the switch circuit, usually the switch but could be wiring as well.
The proper way to fix a S-Series automatic is to replace it with a manual |
#5 | |
Found the switch! Thanks! It was located on the bottom left face of the dashboard. Turns out, it was jammed inside and wouldn't pop out nor compress anymore to close the circuit. A pair of pliers did the trick
![]() Quote:
Actually since the car thinks one door is always open, the dome light will always be on. But this still helped me prove that this was the actual reason for the locks not working, and that I needed to go find that switch ![]() |
Bookmarks |
What could be wrong with my drivers side rear automatic door lock? | 2002SaturnMan | S-Series Tech | 7 | 09-01-2013 02:23 PM |
PLEASE HELP - 2002 SL1 rear automatic door lock not working | 2002SaturnMan | S-Series Tech | 1 | 08-09-2013 06:26 AM |
Automatic door lock/unlock | 2008Vuer | 2008 Vue | 2 | 03-31-2013 09:10 AM |
RADIO problem? and door lock problem please help | 95sl2urbo | S-Series Tech | 15 | 01-11-2004 09:25 PM |
L automatic front and rear door lock actuators | IceMan2 | L-Series Tech | 0 | 07-25-2003 10:20 PM |
