Old 08-20-2017, 01:57 PM   #1
2000sl1blue
2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light2000sl1blue is a glorious beacon of light
2007 SKY Red Line
Default A CM off TDC for timing
I finally got around to getting my woodruff key back and onto my new crankshaft. Now at this point I put back on the crankshaft pulley and attempted to turn it about a CM so it would line up perfectly to TDC markings. The issue is no matter how much weight I put on that big bolt the crank doesn't turn! And it hardly needs to move a CM. Anybody have any tips? Is it even needed to be on center? It's aligned more or less just not perfectly centered.. Spark plugs are out
Add to 2000sl1blue's Reputation
Rate the quality of this post and help 2000sl1blue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2000sl1blue is offline   Reply With Quote
Old 08-20-2017, 03:09 PM   #2
2000sl1blue
2007 SKY Red Line
Default Re: A CM off TDC for timing
I went and bought an 18" 1/2 extension and used a 3' piece of pipe on my breaker bar with all 200lbs of my weight.. It won't budge, not even a little bit. I am in neutral and my clutch feels normal when pressed in. The engine has been sitting rebuild with no oil for about a week or so no, could something have bound?
Old 08-20-2017, 04:25 PM   #3
Did you use assembly lube on the rod and main bearings with NOTHING on the back side? Did you check that the crank would turn after the mains were in and torqued? Did you check after each rod bearing pair was assembled that it would turn? Did it turn when you installed the timing chain? If YES for all then pull plugs and put about a tablespoon of good clean 5w-30 into each cylinder and let it set over night.
Old 08-20-2017, 04:28 PM   #4
2000sl1blue
2007 SKY Red Line
I used assembly lube and none on the back of bearings. After installing the pistons/rods an all I didn't try to rotate anything, so I have no idea. I'm fairly sure that with the pistons in it likely wouldn't have moved easily as it was fairly hard to press in the pistons
Old 08-20-2017, 04:53 PM   #5
Did you use assembly lube on the cylinder walls? If NO then try the oil and soak.
Old 08-20-2017, 06:10 PM   #6
billr
Resist any urge to try cranking it with the starter. If you can't get it to rotate by hand, something is "not optimal" in this rebuild. Don't risk damage to these new parts by forcing the crank to turn.
Add to billr's Reputation
Old 08-21-2017, 09:40 AM   #7
2000sl1blue
2007 SKY Red Line
I didn't lube the walls "/ I'm gonna try the oil soak and hope for the best
Old 08-21-2017, 11:57 AM   #8
billr
I suggest using GM-type ATF (Dex3) for that soak, it seems to migrate everywhere easier than engine/hydraulic oils. Use plenty, just be sure to turn the engine (if you can!) several rotations with the plugs out to purge it enough to prevent hydraulic-lock when the plugs are back in.
PS: you used no oil at all on the pistons/rings when installing them? That must have been a "painful insertion"! I have to push pretty hard on pistons to get them through a ring compressor even when well-slobbered with oil. No turning of the crank with the first two pistons in to get easier access to the other two rod caps?
Old 08-21-2017, 05:28 PM   #9
Use engine oil, not ATF. Keep the ATF out of a new engine. The oil will properly lube the rings. As you did not lube the cylinders before the piston/ring install give it a couple of days soak time.
Old 08-21-2017, 06:50 PM   #10
billr
How about this for a compromise?
Use ATF first, then follow up with a dosing of oil. If the oil will get into everywhere, then it will flush out the ATF. If the oil won't get everywhere, ATF is better than nothing...
Old 08-21-2017, 08:04 PM   #11
This engine is already bound up by tight cylinder clearances and no lubrication. Tight bearings are also a possibility. Using a low film strength friction modified lube (ATF) is just not a good idea at this point as scored cylinder walls and potentially wiped bearing(s) is not worth the risk. If you wanted to use a low viscosity oil then a product that has decent film strength such as KROIL would be my choice.
Old 08-24-2017, 07:45 PM   #12
2000sl1blue
2007 SKY Red Line
Mad Re: A CM off TDC for timing
Well I've been refilling each cylinder with 5w30 the past couple of days to get them lubed up. Since no I didn't lube those walls.. I just went and tried again, I used my breaker bar, and broke the bars socket converter haha!!! Didn't budge even a little though.. I really don't wanna pull out the engine again lol
Old 08-24-2017, 08:16 PM   #13
Did you try turning the crankshaft in the opposite direction? If timing was off just enough to have one piston meet one valve, the engine won't turn any further. Backing off in the other direction without resistance would verify a mistake in timing.
Old 08-24-2017, 08:42 PM   #14
2000sl1blue
2007 SKY Red Line
When I go counter clockwise the bolt just loosens. And right now I don't actually have the rockers on the springs. I'm desperate so I just tried the ATF fluid.. Worse case it works, worst it doesn't and I leave the car here as a parts car haha....
Old 08-24-2017, 08:50 PM   #15
What usually causes this is there is either a couple rod and/or main bearings that are tight, it does not take much at 0 or 180 degrees to lock it right up.
Old 08-24-2017, 11:03 PM   #16
billr
"Socket converter"? Do you mean an adapter to use a 3/8"- drive socket on a 1/2" breaker-bar, with an extender (pipe) on the breaker? Yeah, that often doesn't work out well. I've had to do it too, but had similar results in some cases.
Back to the real problem...
You could probably determine what is wrong with the engine still in the car, by pulling the pan, loosening bearing caps, and fussing with pistons/rod to see what is bound up. However, the binding may well be in the piston/ring/cylinder surfaces and fixing that would require removing the head again and checking everything over carefully. I recommend pulling the engine and doing a bunch of inspection and then re-assembly, hopefully using most of the same "new" parts that you already have.
Old 08-24-2017, 11:50 PM   #17
2000sl1blue
2007 SKY Red Line
Is it possible to pull the pan with the engine in the car? It seems like the bolts for the pan aren't able to be accessed next to the flywheel. And I'm never pulling another engine again now even to salvage this rebuild hahahaha. I'm willing to drop the pan again, but I don't know how much further I'll go. I might just hook it to the starter and see what happens at this point
Old 08-25-2017, 12:07 AM   #18
2000sl1blue
2007 SKY Red Line
I think I did all caps to 33-36 ft lbs
Old 08-25-2017, 12:35 AM   #19
You'll need some imagination to turn the crankshaft in the opposite direction.....
Old 08-25-2017, 07:27 AM   #20
billysvue
That would be like driving it off a cliff. Nothing good can come of using the starter if you can't turn the motor over by hand.
Pistons and valve are kissing or bearings are tight, somewhere.
Got Plastigauge?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
crank position for timing without removing the timing cover 03232001 S-Series Tech 9 10-03-2015 06:59 PM
sounds like the timing chain coming in contact with timing cover prioris S-Series Tech 3 12-08-2012 01:12 AM
timing chain sounds like it could be coming into contact with timing cover prioris Sky Tech 0 12-07-2012 10:31 PM
Timing Chain Replacement - Trouble Setting Timing neeco S-Series General 13 10-31-2011 02:02 PM
Help! - Timing Belt L81 - AC Delco -Rock Auto Kit - Timing Mark Question oldvue Vue Tech 5 09-16-2010 04:55 PM
