Old 09-01-2017, 02:06 PM   #1
rick_ca
rick_ca is on a distinguished road
Default 2003 Ion Brake Problems
Brake issue here so story so far brakes really soft so replace one rear cylinder and bleed in this order passenger rear, driverís rear, passenger front and drivers front. Clean new dot3 in all lines and brakes still soft so purchased a master cylinder and before installing bleed best you can do with the strange design of those things. Now brake pedal super hard and cannot depress it at all so also canít shift the auto gear shift, SO what have I missed or screwed up
Add to rick_ca's Reputation
Rate the quality of this post and help rick_ca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rick_ca is offline   Reply With Quote
Old 09-01-2017, 02:46 PM   #2
Default Re: 2003 Ion Brake Problems
What does ".....bleed best..." mean? With a new master cylinder, is there a lock or blocking device on the output ports or cylinder rod, preventing master cylinder piston travel until its removed prior to installation? Is the brake pedal cocked in such a way preventing normal travel?
Old 09-01-2017, 03:58 PM   #3
rick_ca
No Lock on this master cylinder when I say ďbestĒ i mean bench bleed while trying to hold reservoir in approx. location as to where it is on car from cylinder and maintain liquid level while manually pumping piston
Old 09-01-2017, 04:51 PM   #4
billysvue
2005 VUE 2.2L
Originally Posted by rick_ca View Post
Brake issue... Now brake pedal super hard
Is it the same way if you crack a bleed screw on the passenger front brake caliper?
Are yo u in the Rust Belt?
Look at the first fixed mounting point( on the body/frame) of the front flexible BRAKE lines to each caliper, Is it rusted at all?
CAn you rotate any wheel by hand in neutral/park brake off/ jacked up , of course)?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 09-01-2017, 07:20 PM   #5
rick_ca, if you tried bench bleeding, unless your master cylinder is clamped into a vise or holding fixture, you may be feeling the return spring inside, preventing hand pushing the master cylinder rod. If so, mounting it in place on the car should allow in-car master cylinder bleeding after both brake lines are connected (loosening each one for bleeding before bleeding the rest of the brake system). Normal brake flushing/bleeding procedures are usually right passenger rear/left driver front (RR/LF), left driver rear/right passenger front (LR/RF). The basic brake system is divided into two halves. If one wheel leaks, that half of the brakes are lost but the other half remains in operation to bring a car slowly to a stop.
Re-check your mechanical connections of brake pedal linkage, rod to vacuum boost and master cylinder rod alignment.
Old 09-01-2017, 10:51 PM   #6
rick_ca
Thanks for all the suggestions I just finished watching a Scotty Kilmer utube video which Iím going to try tomorrow and post the results
Old 09-02-2017, 11:12 PM   #7
rick_ca
ok I screwed up on install found problem had to hold brake pedal in 1/2 way position then align before installing cylinder to firewall, i now have partial brakes and going to bleed all lines tomorrow.
Old 09-03-2017, 12:41 PM   #8
Great progress! Owning up to mistakes and learning from them allows moving forward. Let us know your outcome.
Old 09-05-2017, 05:17 PM   #9
rick_ca
Ok bleed the brakes no air in lines but pedal still feels spongy might have to bite the bullet and take to the shop and have them rip me
Old 09-05-2017, 07:46 PM   #10
spenser4
spenser4 is on a distinguished road
I will try to attach service manual. How to manual bleed drakes.
Add to spenser4's Reputation
Rate the quality of this post and help spenser4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spenser4 is offline   Reply With Quote
2003 vue brake issue mike.jeltema Vue Red Line 4 04-12-2014 10:03 PM
2003 Vue AWD brake issues niteowl2k Vue Tech 1 08-21-2013 02:30 PM
2003 Vue V6 FWD problems. lodingi Vue Tech 9 12-18-2008 09:17 PM
Bad brake job on 2003 lw300? middleman L-Series Tech 3 12-05-2007 04:03 PM
2003 Ion 2 Problems Pipboy Ion Tech 6 01-15-2007 01:17 AM
