Old 08-27-2017, 05:38 PM   #1
tecky11
tecky11 is on a distinguished road
Default transmission fluid
ok, did some more owrk on the car today. changed the oil and checked tranny fluid, its dark and burnt and needs to be replaced. how much and what type of ATF does it take? Also where do you get an AC delco water pump/timing kit???? We have a 3.0 v6
2003 saturn vue 3.0 v6
1973 International 345 v8 auto
2007 saturn Ion 2.2/auto donor car
Add to tecky11's Reputation
Rate the quality of this post and help tecky11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tecky11 is offline   Reply With Quote
Old 08-27-2017, 07:45 PM   #2
billysvue
Default Re: transmission fluid
maybehttp://lmgtfy.com/?q=2003+saturn+v6+trans+fluid
I would think any FLAPS would have your parts( or ROCKAUTO)
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 08-27-2017, 08:13 PM   #3
col_dude190
col_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura about
2006 VUE Red Line
2004 ION-3 Quad Coupe
To actually answer your question, the '02/'03 Vue's with the 3.0 has an Aisin transmission that uses ATF T-IV. It's usually tough to find regular T-IV at a normal auto parts store. The cheapest place to find it is usually your local Toyota dealer. It typically runs about $5 a quart. It's also readily available on Amazon.
Valvoline Maxlife ATF claims to be T-IV compliant, and most auto parts stores carry Maxlife ATF. If you're looking for a quick, readily available option, Maxlife is definitely an option. It's a good quality fluid that can be used as an alternative to T-IV.
As far as the AC Delco timing belt kit, don't bother hunting it down. The AC Delco kit is just a standard Gates kit in an AC Delco box, along with a GM markup. Just get the Gates kit, which will include the updated adjustable pulleys for the 3.0 and is readily available almost anywhere.
Add to col_dude190's Reputation
Rate the quality of this post and help col_dude190 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
col_dude190 is offline   Reply With Quote
Old 08-27-2017, 08:38 PM   #4
Chazberry
Chazberry's Avatar
1995 SW2
Pick up 5 Qts of T-IV.
I used the Gates TCK285BP kit.
Compare Rockauto and Amazon.
Add to Chazberry's Reputation
Old 08-28-2017, 04:48 AM   #5
tecky11
thanks much, will def do that
Old 08-28-2017, 04:50 AM   #6
tecky11
awsome thanks for the info. didnt realize how much of a ******* it is. is th4e Aisin tranny any good??? are they decent transmissions??
Old 08-28-2017, 10:33 AM   #7
Chazberry
Chazberry's Avatar
1995 SW2
I think they are a very solid tranny - we see very few problems posted here. The TCM is probably more likely to cause issues.
Old 08-30-2017, 12:26 PM   #8
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
I remember when I had my VUE, I would get the T-IV fluid from Toyota, and it was cheaper than from the Saturn dealer.
It's GOOD to have a spare!
Add to termite's Reputation
Rate the quality of this post and help termite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
termite is offline   Reply With Quote
Old 08-30-2017, 02:01 PM   #9
atikovi
If it's dark and burnt, you will have to change it at least 3 times with a few miles drive in between to get it looking decent.
Add to atikovi's Reputation
Old 08-30-2017, 03:47 PM   #10
tecky11
that is the plan, just called a toyota dealer, 4.95 per qt. will be ordering 2 cases soon as we can
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 07:47 PM
Small transmission fluid leak from radiator transmission cooler line EvanVanVan S-Series Tech 5 10-13-2014 07:55 PM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 06:57 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 06:04 PM
Transmission Fluid flow from Transmission into the radiator ? Luke S-Series Tech 5 11-10-2005 11:52 AM
