Old 08-25-2017, 09:16 AM   #21
Default Re: A CM off TDC for timing
Originally Posted by 2000sl1blue View Post
Is it possible to pull the pan with the engine in the car? It seems like the bolts for the pan aren't able to be accessed next to the flywheel. And I'm never pulling another engine again now even to salvage this rebuild hahahaha. I'm willing to drop the pan again, but I don't know how much further I'll go. I might just hook it to the starter and see what happens at this point
If it is an automatic you can get the pan out. Might have to drop the head pipe as well. If you disconnect it behind the cat and at the manifold you can rotate the REAR end to the LEFT side of the car and it will drop clear of the radiator etc. If careful you do not have to disconnect the rear O2 sensor either.
If you do not have the timing chain on and the cam sprocket is not pinned to TDC the valves will not lock the engine, they bend very easily.
Old 08-25-2017, 09:32 AM   #22
FYI plastigauge has been repeatedly demonstrated to be quite inaccurate. Direct measurement is required for accuracy.
The pan can also be removed if a manual trans but you will have to buy a new one as the rear corners will have to be cut/bent to get it out of the flywheel.
Old 08-25-2017, 10:07 AM   #23
billysvue
2005 VUE 2.2L
Of course, just use as a go /nogo indicator for crank/rod bearings
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 08-25-2017, 12:01 PM   #24
If you use a good quality assembly lube and then check for free rotation after each bearing is installed and torqued this eliminates the need for plastigauge.
Old 08-25-2017, 12:41 PM   #25
billr
If those piston/rings got put in dry, I think a ring has probably broken or otherwise galled to a cylinder wall. If the OP doesn't want to remove the engine and inspect it properly, it is toast. Let it RIP.
Add to billr's Reputation
Old 08-26-2017, 07:20 PM   #26
Highmile
Highmile's Avatar
I'm betting piston to valve interference.
So if this is a single cam motor you should be able to loosen the caps on top of the cam until all the valves are close.
The down side if this is the case you may have put enough pressure on a valve to bend it. So once in time then put the chain on, tighten the cam caps and run a quick compression test.
Best part it is quick and easy to loosen the caps to check for interference
Highmile
'95 SL1 637k and counting
Add to Highmile's Reputation
Rate the quality of this post and help Highmile reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-26-2017, 08:35 PM   #27
billr
The OP reported (reply #14) that the rocker-arms aren't in yet; not much chance any valves have hit a piston.
Old 08-26-2017, 10:15 PM   #28
billysvue
2005 VUE 2.2L
THe context I was envisioning was using it as a clearance gauge- measuring the thickness of the squashed Pgauge with a cheap dial indicator after the caps were installed( then removed to access) .
Maybe a piece of grit was trapped under a crank main bearing. Or just wrong thickness.
Or what you suggested, dry/broken rings. I can't imagine going to all that trouble and not using lube on the rings.
'17 Suby Forester
Old 08-26-2017, 10:18 PM   #29
billysvue
2005 VUE 2.2L
Good catch,,, I guess that leaves just dry rings and( more remote) binding crank/rod bearings.
'17 Suby Forester
crank position for timing without removing the timing cover 03232001 S-Series Tech 9 10-03-2015 06:59 PM
sounds like the timing chain coming in contact with timing cover prioris S-Series Tech 3 12-08-2012 01:12 AM
timing chain sounds like it could be coming into contact with timing cover prioris Sky Tech 0 12-07-2012 10:31 PM
Timing Chain Replacement - Trouble Setting Timing neeco S-Series General 13 10-31-2011 02:02 PM
Help! - Timing Belt L81 - AC Delco -Rock Auto Kit - Timing Mark Question oldvue Vue Tech 5 09-16-2010 04:55 PM
