#81 | |||||
![]() Join Date: Jan 2012
2004 VUE Red Line
#82 | |||||
![]() Join Date: Feb 2012
2004 VUE Red Line
Did you go 235 or 245? ... ____________________________________________________________________ Black '04 Redline: Tint- HIDs- Quad Light Mod- Signal Mod- Badges Shaved- Smoked Tails/Corners - Dipped Rims
#83 | |||||
![]() Join Date: Jun 2010
2006 VUE Red Line
2007 AURA XE
These tires list at Canadian Tire for around $260 each, and say the start with 9.5/32 tread.... well these ones I found still had 7.5/32 but only cost me $225 for all 4. ![]()
#84 | |||||
![]() Join Date: May 2008
2006 VUE Red Line
I have a serious issue now with this specific Kal Tire because they completely buggered my pristine stock rims up! And the clown that balanced them did a horrible job and the vehicle now shakes pretty good around 100-110 km/h! Everything was fine when I went in this morning. What a disaster! Have to go back there tomorrow and chew them out. I am so p@#%!d tonight! I have a feeling this will end up in small claims court. Sorryto hijack the thread but I had to vent..... ... .................................................. Saturn Vue: The 250 HP tupperware
#85 | ||||
Here are a few pics of the new tires...
![]() ![]() ![]() ... Avid Apple, car and vacuum enthusiast. Don't hate! ;) Current: '04 FWD 3.5L Previous: '05 AWD Red Line '02 L200 http://www.facebook.com/SaturnFansNorthEast
#86 | ||||
![]() Join Date: Sep 2009
2006 VUE Red Line
Redgemini,
What size did you go with? I am needing tires asap and I went to a shop and they're trying to put me in a 235 40 R18. I am so damn confused on what these tire sizes mean. They gave me two options 1. Hankook Optimo H426 ($850.00 w/ $50 rebate) 2. Kuhmo Solus KL21 ($860) Both have bad reviews in wet weather and only rated for light snow. Well I live in MN, so an all season tire that is good in snow is ideal. Please help me with sizes of tires that I can put on my RL at a good price and are decent in snow. I am on a budget big time. ... 2006 Vue RedLine.
#87 | |||||
2006 VUE Red Line
2007 AURA XE
I believe stock are 245/50/18.... that's what my current tires are.(edit) Just put vehicle info into Canadian Tire site and it came up with 245/50/18 for standard size on a Redline. Edit- reread your post.... too clear up confusion first number is width of tire in metric I believe, second number is a ratio of height of tire wall to width. So 40's would be shorter than 50's as 40 means tire wall height is 40% of width. Lastly the third number is the most obvious, it's the rim size. Last edited by Vue in Ontario; 09-23-2012 at 08:50 PM..
#88 | |||||
![]() Join Date: Feb 2006
2006 VUE Red Line
2004 VUE Red Line
The tire that many of us have been going with is the BFGoodrich Radial T/A in the 245-55-18 size. They are just a hair taller than the stock tires, but they are VERY reasonably priced at around $350 to $400 for a set depending on where you get them. They are the stock all seasons on the base model Camaro, which probably has something to do with the bargain basement price. I have got them on both of our Redlines and they have great grip and they ride at least as good, if not better, than the stock Turanzas. I have found them to be pretty good in snow, although there is no replacement for good snow tires IMO. A few other owners on here have them as well. If you look through the posts in this thread, you will find all the info that you need on them. Any shop that sells BFG tires should be able to order them, although my preference is to order them online through tirerack or discount tire (who often offers a mail in rebate for BFG tires) and then have them mounted locally. Best of luck with your tire search! ![]()
#89 | ||||
2006 VUE Red Line
Thanks for the help on this.
#90 | |||||
![]() Join Date: Jul 2012
2005 VUE Red Line
Last thing....you need to also look at the warranty. I have already had tires that the tread life wore out before the warranty did. All season non z or x rated, non touring tires will last the longest, the sportier the tire, the softer the tire..the quicker it wears out. (keep in mind their are exceptions but that is the general theory on tires) more grip usually means less tread because to get good grip, you need softer tires. Mine came with Z rated tires...I forget the name because I will NOT be getting them again, I drive tooo much to have soft sport "v" treaded tires!
#91 | |||||
#92 | |||||
#93 | |||||
2005 VUE Red Line
I just found 2 sets of Kumho Majesty Solus KU50 Tires $250 a set with free shipping. Now that was just blindly looking and putting them in the order of cheapest first...plus it cost more to buy four at once then 2 sets of 2 lol weird. Don't know their rating or anything so maybe they suck but 500 bucks is a reasonable price for tires to me because my nissan altima had 16's and I spent 420 on four tires for that car (granted I got lower profile and wider ones). BUT I do see tires in that size that cost a LOT more....I think you just have to take the time and look and you can truly find some in the right size :-)
#94 | |||||
2006 VUE Red Line
2004 VUE Red Line
They are IMO only a hair taller as you only get about an extra half inch on each side of the wheel (about an inch added to the total diameter of the wheel and tire). Not only do they still offer the excellent grip of the stock tires as they have the same 245 width, but you also get a better ride because of the higher sidewall. It's not like they are monster truck tires...the 55 sidewall is still pretty stiff. They are also much better looking IMO because, even with the Redline package, the Vue has HUGE wheel well gaps from the factory with stock size tires. Going with a huge wheel and a low pro tire that still maintains the factory wheel/tire diameter will not fix this issue. The slightly higher sidewall fills those gaps much more effectively than the stock tires and makes the Vue look MUCH better IMO. Add in the low price compared to the stock 245-50-18s and you have a great all around tire. Again just my 2 cents
| Thread Tools | |
| Display Modes | |
| I've Had Two Defective Astras, So I Finally Decided To . . . | davebowman | Astra General | 11 | 12-19-2008 08:06 PM |
| Finally: new wheels / tires | mdcclxxvi | Astra General | 17 | 09-09-2008 05:41 PM |
| Finally, new tires........ | mpmont | Vue General | 6 | 11-15-2005 07:39 PM |
| Finally Decided on The ION-2(Manual) | kbg1 | Ion General | 1 | 07-19-2005 10:02 PM |
| Finally, a valid reason for new tires. | bobwill | Ion General | 4 | 06-01-2003 11:00 PM |
