Old 03-14-2019, 05:56 PM   #1
Turbo1002
Turbo1002 is on a distinguished road
Default Condenser replacement
Need to replace the condenser on 99 sl2. I have searched and looked on youtube with no success. Does anyone have a procedure how to take the condenser out? Does the radiator have to come out or get pushed back? Does the condenser come out the top or bottom? I have much experience with refrigerant, that is not a problem. Every car has a different way of getting at certain parts an easy way and the hard way. Thank you.
Add to Turbo1002's Reputation
Rate the quality of this post and help Turbo1002 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Turbo1002 is offline   Reply With Quote
Old 03-14-2019, 06:38 PM   #2
Default Re: Condenser replacement
You've been here long enough to know, no one can answer your question (honestly) unless you provide car stats. Put them into your personal profile to show up under your name. Year and model won't be asked every time a question is posted.
Old 03-14-2019, 06:44 PM   #3
Turbo1002
I will put them in the profile. I did include the year and model in my question.
Old 03-14-2019, 07:54 PM   #4
trottida
trottida's Avatar
Condenser is attached to the radiator. If I recall correctly you can detach it from under the car reaching up. Two 10mm bolts at the bottom with speednuts and the other 2 attachments are just hooked at the top.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 03-14-2019, 09:07 PM   #5
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
I'm no mechanic but managed to replace my radiator without any problems. The condenser is just a easy. My only comment is you are dealing with an old car, the cooling lines may break when you try to remove them so be prepared for that.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 03-14-2019, 11:24 PM   #6
Waiex191
Waiex191's Avatar
Cool, please post pictures as you go. My condenser is banana shaped from the PO's offroading adventures. Hoping to replace it and get the AC working.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 03-15-2019, 10:05 AM   #7
Turbo1002
Thank you for the PDF image helped greatly.
1999 SL2 DOHC
Old 03-19-2019, 11:56 PM   #8
RocketRanger125
RocketRanger125 is on a distinguished road
Per the nasty fittings at the drivers side of the condenser sure to common corrosion, I would replace the discharge hose and dryer/receiver and all corrosponding prongs. If system is open, suction line aswell. Consider all corrosponding oil loss/add for the 2 major items.
If entertaining the dryer/receiver, I certainly liked the bumper removed along with the gender skirts... The drivers headlight assembly is very helpful to remove when servicing any of these items.
Add to RocketRanger125's Reputation
Rate the quality of this post and help RocketRanger125 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RocketRanger125 is offline   Reply With Quote
AC oil after new condenser 2000sl1blue S-Series General 3 07-13-2017 04:19 PM
SC Condenser cityhawk S-Series Tech 3 08-12-2016 05:28 PM
02 saturn l300 3.0 ac condenser replacement mrhappypantz L-Series Tech 20 07-03-2016 12:54 AM
2004 3.5L Saturn Vue Condenser Replacement captUSSR Vue Tech 14 03-11-2016 04:47 PM
A/C Condenser replacement etp26 L-Series Tech 2 05-06-2012 05:53 PM
