Old 03-17-2019, 08:14 AM   #1
Importgurl
Importgurl is on a distinguished road
Question Grinding/noise when in reverse and the car won't move
My mother has a 2004 Saturn Vue v6 redline. Well about a week ago she had been having trouble with putting the Vue in reverse to back up, it grinds and won't move. It doesn't do it all the time just most of the time, like she can trim the car off and back on then it will let her back up. It is throwing two codes.... P0705 transmission range switch sensor/neutral safety switch.... And then the code for the O2 sensor bank 2, what could be the problem plz help .. it does have a slight High idle. She did say once when she tried starting it made the same grinding noise.
Add to Importgurl's Reputation
Rate the quality of this post and help Importgurl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Importgurl is offline   Reply With Quote
Old 03-17-2019, 11:06 AM   #2
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: Grinding/noise when in reverse and the car won't move
A couple of thoughts ... transmission PARK/NEURTRAL switch could be out of adjustment or failing.
Have Mom try shifting from PARK to NEUTRAL and then back to reverse to see if it improves engaging reverse gears.
I can email extracts to replace and/or adjust the PN switch ... PM address if interested.
Can you post the exact O2 sensor code? There are several O2 codes - a few are set by failing sensor and others could indicate bad wiring or fuse(s).
I try to visit forum daily but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 03-17-2019, 02:58 PM   #3
Importgurl
Yes plz email the replace and or algin the PN plz.... tonyaharrington29@yahoo.com thank u. I will have my mom try the park into neurtral the reverse when I get home. And the code that pops up for the 02 sensor is P0036.... Thank u for feedback and advice.
Old 03-17-2019, 07:13 PM   #4
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
I'll email several extracts and you can email further questions or post to forum.
Re O2 sensor - P0036 is for Bank 1 Sensor 2 heater circuit - heater wiring for both bank 1 sensors is provided by same fuse so if you don't have a P0030 code the problem is probably internal to sensor.
BTW - bank 1 is three cylinders nearest windshield and sensor 2 would downstream or after the catalytic converter.
Old 03-18-2019, 11:23 AM   #5
Importgurl
Thank u for email with all the info. I will forward them to my brother in-law.
Grinding Noise Shifting Into Reverse Hunter44 S-Series General 6 01-03-2014 11:30 PM
Grinding Noise Shifting Out Of Reverse Hunter44 S-Series Tech 3 12-30-2013 09:18 PM
Saturn grinding noise when shifting from reverse to park leukram S-Series Tech 2 05-15-2011 01:01 PM
Reverse slam and grinding noise 94Saturnmania S-Series Tech 0 03-26-2011 11:39 PM
No reverse. Load grinding/winding noise 2002 SL2 AT mandc S-Series General 0 02-17-2011 06:36 PM
