Old 01-29-2006, 12:41 PM   #1
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Cool Torque axis mount replacement
I would like to thank all the members for the info on replacement of this part. I replaced it[oem w/studs and nuts] yesterday and it made a large improvement as my 1995 sl1 no longer vibrates and feels like a new ride.
I have one other problem to solve: When I start up cold in
the morning and put the car in reverse and backup my long driveway[60 feet] I hear a dull clunk/rattle from the left front strut/wheel area. I checked all boots and also checked for loose front end parts none found. I can the go about 1 or 2 blocks and then it is gone. Later if the car sits and gets cold it will happen again. Any ideas?
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-30-2006, 08:22 PM   #2
SRGW
1997 SL1
Default Re: Torque axis mount replacement
Bump?
Old 01-30-2006, 09:24 PM   #3
dansl2
dansl2 is on a distinguished road
dansl2's Avatar
2000 SL2
Does it happen at the same place/time on your driveway every time? Maybe tell your kids to pick up their toys?
Experience is something you don't get until just after you need it.
Add to dansl2's Reputation
Rate the quality of this post and help dansl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dansl2 is offline   Reply With Quote
Old 01-31-2006, 10:28 AM   #4
jjsk8r85
jjsk8r85 is on a distinguished road
jjsk8r85's Avatar
1992 SC
check out the boots on the drivers side CV axle, as they may be torn, hence all the grease in the joints drying up, hence your wallet draining to replace the axle. ESPECIALLY since you just replaced a mount. if the mount was horribly broken, you may have ripped a boot on the CV axle.
Add to jjsk8r85's Reputation
Rate the quality of this post and help jjsk8r85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjsk8r85 is offline   Reply With Quote
Old 01-31-2006, 12:50 PM   #5
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
If a car vibrates because of a bad TAM would it normally stop vibrating after the car warms up?
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 02-01-2006, 11:15 AM   #6
Luke
Luke's Avatar
No, not necessarily.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Torque Axis Mount (Upper Engine Mount) Problem kickflipjr S-Series Tech 7 03-10-2006 03:28 PM
Torque Axis Mount (Upper Engine Mount) Replacement wolfman How-To Library 29 10-30-2005 04:00 PM
torque axis mount... S3aturnR S-Series General 2 08-08-2005 02:49 PM
Nut Torque Specs for 1999 SL2 Torque Axis Mount todd8 S-Series General 3 05-01-2005 01:34 AM
Torque axis mount DaveL167 Miscellaneous Tech 2 04-19-2003 10:38 PM
