Closed Thread
Old 08-26-2003, 12:11 AM   #1
wolfman
wolfman's Avatar
Wrench Torque Axis Mount (Upper Engine Mount) Replacement
The "Torque Axis Mount" is located on the passenger side TOP of the engine on all "S" series (DOHC and SOHC) cars made from 92'-02'. The 91' SOHC (SL, SL1) DO NOT have this mount. It is a "U" shaped metal/rubber mount secured to the engine with 3 15mm/nuts and to the space frame with 2 15mm/nuts. To change it you will need:
Floor jack with a block of wood or rolled up piece of carpet to act as a "cushion"
15mm DEEP WELL socket and wrench
Proceed as follows.
With a block of wood or carpet padding the floor jacks "pad" to protect the oil pan, place it under the front passenger side portion of the oil pan as close to the frame as possible.
Jack up the engine about 1 INCH (you'll see it move) to relieve pressure on the mount.
Using the 15mm deep well socket, remove the 5 15mm nuts holding the mount to the engine and space frame. (3 engine side, 2 spaceframe side)
Lift UP (yank might be a better word) on the old mount to remove it.
Slide the new mount down over the studs on the engine/frame and reinstall the nuts using the 15mm socket. Torque "should" be 20~25 ft pds BUT do not be overly concerned here, just DON'T wrench down to the extreme and things will be fine.
Lower the jack and remove it from under the car.
NOTES:
Often the studs will unscrew out of the engine instead of the nuts coming off the studs. This can be prevented by spraying the nuts with some "PB Blaster" or similiar penetrating oil the night before you plan on changing the mount. Even if they DO still unscrew with the nuts, you CAN just treat the entire thing as a "bolt" when reinstalling it BUT start it back into the hole in the ALUMINUM cover BY HAND to ensure you don't cross thread it!
If your mount has NEVER been changed, (and even if it has) get the part from SATURN, aftermarket mounts although cheaper, have shown to have fitment and quality issues. A new mount from Saturn "may" (depending on the year of your car) need 3 new studs and 5 new nuts to go with it at an additional expense. GET THEM. They simply unscrew out of the engine cover like long bolts using an adjustable wrench. When installing the new studs (if you do) start them into the holes BY HAND and then tighten them until they bottom (nearly all the lower threads disappear into the hole) DO NOT overtighten the new studs! 20ft pds (snug) is ALL that is required!
For you time and expense, you will be amazed at how much better the car will sound and feel with the engine running.
Add to wolfman's Reputation
wolfman is offline
Old 08-26-2003, 10:08 AM   #2
Luke
Luke's Avatar
Default
Fm Wolf
In addition: As was the case with my car, I did not need the new studs. But, when I picked up the mount, the dealer aggresively told me that I would need it. I took the studs & nuts (not cheap) under the conditions that I could return them should it be found that they were not needed. As they were not, was able to return them for a full refund. Keep this in mind with picking up a new engine mount.
Add to Luke's Reputation
Rate the quality of this post and help Luke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luke is offline
Old 08-27-2003, 09:44 AM   #3
amazinghl
Default
Yup, get the studs and nuts if you're not sure, then if you don't need them, you can always get a refund later.
00 Insight 72mpg
Add to amazinghl's Reputation
Rate the quality of this post and help amazinghl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
amazinghl is offline
Old 10-18-2003, 10:26 PM   #4
Lurker1999
Lurker1999 is on a distinguished road
1993 SC2
Default
Here's some additional tools that I found quite helpful in the process:
6 inch 3/8" extension
7mm socket, 6 point, 1/4" drive
3/4" x 2 foot pipe as a breaker bar
If you spray the nuts with penetrating oil the night before everything will go much smoother.
You don't have to jack the car up. You can use the space in front of the passenger side front tire and the wheel well to lever your hydraulic floor jack up without needing to raise the front of the car.
You will likely want the extension with the breaker bar so you can exert enough force to undo the nuts without banging into anything.
You likely will not need new nuts but may need new studs. Buy both and return what you don't need.
There are two lengths of studs differing by about a half centimeter. The new studs appeared to have been coated with something
Be sure to check that the bottom of the mount with the frame side bolted loosely is flush with the top edge of the engine before you try to tighten things down. If they don't meet up exactly use the lift to raise the engine a bit.
Enjoy the vibration free ride (I am)!
93 SC2a 69k
Add to Lurker1999's Reputation
Rate the quality of this post and help Lurker1999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lurker1999 is offline
Old 10-19-2003, 02:23 PM   #5
Luke
Luke's Avatar
Default
Fm Lurker
You likely will not need new nuts but may need new studs. Buy both and return what you don't need....
But...in advance, get understanding from the parts department, should you find that the new studs are not needed, that you can return them. Without this advance understanding, some dealers will not accept returns.
Just a safety thought -- cover yourself in advance..
Luke is offline
Old 09-14-2004, 10:49 PM   #6
SpeedPlayer 97sl2
SpeedPlayer 97sl2 is on a distinguished road
SpeedPlayer 97sl2's Avatar
Default Re: Torque Axis mount (upper engine mount) replacement
Unless your mount is completely shot like mine was the second time I changed it, you may need to lift the engine a little more. I lifted one inch to remove the old mount, but had to lift it an additional inch once I slipped the new mount on to get the studs to stick out sufficiently.
My reality check bounced.
Add to SpeedPlayer 97sl2's Reputation
Rate the quality of this post and help SpeedPlayer 97sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SpeedPlayer 97sl2 is offline
Old 09-15-2004, 08:01 PM   #7
FrozenPilot
FrozenPilot is on a distinguished road
FrozenPilot's Avatar
Default
The top engine mount is super-easy!! I ended up replacing all 3 studs because I had already bent one trying to reach 52 ft/lbs as in the Chiltons book! Can't believe everything you read I guess applies to instruction manuals too now. Either way, $7 for brand new studs is cheap insurance.
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
Add to FrozenPilot's Reputation
Rate the quality of this post and help FrozenPilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrozenPilot is offline
Old 01-03-2005, 12:47 PM   #8
David 93 SL2m
David 93 SL2m's Avatar
2007 ION-3 Sedan
Attention Re: Torque Axis Mount (Upper Engine Mount) Replacement
Sorry I didn't catch this earlier. Wolfman wrote the torque for those nuts is 52 foot pounds for the 1992 S-Series and 37 foot pounds for the 1993 through 1997 and 1998 through 2001 S-Series in the following thread:
http://www.saturnfans.com/forums/sho...to+Engine+Nuts
The last two times I did this procedure I used only 35 foot pounds.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 01-14-2005, 09:23 PM   #9
QwikSC2
QwikSC2 is on a distinguished road
Default Re: Torque Axis Mount (Upper Engine Mount) Replacement
What is the part number for the TAM?
Add to QwikSC2's Reputation
Rate the quality of this post and help QwikSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
QwikSC2 is offline
Old 01-15-2005, 05:08 PM   #10
David 93 SL2m
2007 ION-3 Sedan
Wrench Re: Torque Axis Mount (Upper Engine Mount) Replacement
For the 1992 and later S-Series the part number is 21012185. (The 1991 S-Series cars did not have it.)
If you want to replace the 3 studs and 5 nuts, the studs are part number 11518885 and the nuts are part number 21006320.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 05-07-2005, 04:07 PM   #11
heromeet
heromeet is on a distinguished road
Anyone knows if 98 SL2 needs the studs and nuts?
Based on their parts number, the studs and nuts are for 92-96 saturn. However, my local dealer strongly recommended replacing them. Got confused...
Another question, can I use the small scissor jack in the trunk instead of the floor jack?
Add to heromeet's Reputation
Rate the quality of this post and help heromeet reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
heromeet is offline
Old 11-30-2004, 04:11 PM   #12
s1sharma
s1sharma is on a distinguished road
Wolfman: Do you know how to change lower mount? Your advise were very helpful for upper mount.
Add to s1sharma's Reputation
Rate the quality of this post and help s1sharma reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
s1sharma is offline
Old 11-30-2004, 10:37 PM   #13
the_skin_eater
the_skin_eater is on a distinguished road
the_skin_eater's Avatar
1999 SL1
SeArch the how to section some more. I know some people have pictured steps showing how to, although wolfman did not explain them all, they are still good detailed instructions...
o yeA, search for lower transmission mounts and maybelower motor mounts, they called different things but still the same.
Im not crazy, just bored...
http://www.cardomain.com/id/the_skin_eater ---Chek it out.
All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her...
Add to the_skin_eater's Reputation
Rate the quality of this post and help the_skin_eater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_skin_eater is offline
Old 03-07-2005, 05:01 PM   #14
SimPlyxTriPPiN
SimPlyxTriPPiN is on a distinguished road
SimPlyxTriPPiN's Avatar
1995 SC1
i would like to thank wolfman for this write up. i just replced my TAM and the difference is great especially on acceleration and gear shifts.
Add to SimPlyxTriPPiN's Reputation
Rate the quality of this post and help SimPlyxTriPPiN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SimPlyxTriPPiN is offline
Old 04-14-2005, 01:45 PM   #15
jlevino
jlevino is on a distinguished road
jlevino's Avatar
2004 VUE Red Line
1991 SC
Recently I acquired a 91 SC and I'm in the process of restoring it to drivability. Is it possible to retrofit the 91 model year to accept a top engine mount?
Add to jlevino's Reputation
Rate the quality of this post and help jlevino reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jlevino is offline
Old 04-21-2005, 09:18 AM   #16
Luke
Luke's Avatar
You'd be better off by moving this question over to the S-Series site, for this is the How-To Library; a source for procedures submitted by the techs.
Luke is offline
Old 09-08-2005, 06:22 PM   #17
FredM
FredM is on a distinguished road
FredM's Avatar
I need to do this on my 98 SL2 also. Does anyone recommend using anti-seize (sp?) compound on the studs / nuts?
Or is that a bad idea for this application?
Add to FredM's Reputation
Rate the quality of this post and help FredM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FredM is offline
Old 09-08-2005, 07:08 PM   #18
sunshn1972
sunshn1972 is on a distinguished road
sunshn1972's Avatar
From what little I found on it, the nuts are "pinch" nuts. The threads on the nuts are apaprently cut so that they don't fit the studs exactly and pinch when they are turned onto the studs. I assume this is done to make sure they won't vibrate loose. I assume this is why so many people say to replace the studs and nuts (which I did).
I'd vote for no anti-sieze. I just sprayed some WD-40 on them a couple days before making the change, and there weren't any real problems getting the old ones out. Some nuts came off the studs, and some studs came out with the nuts on them. With the studs that came out the nuts came off esily once I had them out.
Let us know how much of a difference you feel.
This space intentionally left blank.
Add to sunshn1972's Reputation
Rate the quality of this post and help sunshn1972 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sunshn1972 is offline
Old 09-09-2005, 11:27 AM   #19
Creelove
Creelove is on a distinguished road
Creelove's Avatar
1997 SC1
Has anyone tried doing this repair using the Saturn tire jack instead of a floor jack? My 1997 vibrates like crazy in neutral (I'm assuming the problem is the mount) and would love to change the mount myself, but I don't have access to a floor jack.
Also, what is the cost of the engine mount from Saturn?
Thanks!
Add to Creelove's Reputation
Rate the quality of this post and help Creelove reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Creelove is offline
Old 09-09-2005, 11:50 AM   #20
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Thanks!
You can use the saturn jack. It basically just need to support the motor on that side while the mount is off. Make sure you use a block of wood or something to distribute the weigh or you'll likely dent your oil pan.
Mount from Saturn is in the $70 range. Aftermarket (Anchor Brand) is around $40.
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
Closed Thread
Upper engine mount(torque access mount) slv01sc2 S-Series General 21 08-26-2007 02:19 PM
Torque Axis Mount (Upper Engine Mount) Problem kickflipjr S-Series Tech 7 03-10-2006 03:28 PM
Torque axis mount replacement SRGW S-Series General 5 02-01-2006 11:15 AM
Upper Torque Axis Mount Modification Heartbeat - '95 SL2 Mods and Performance 7 12-01-2001 12:46 AM
Torque Axis Engine Mount Nuke-Em Miscellaneous Tech 3 08-31-2001 07:41 PM
