Old 11-30-2005, 12:01 PM   #1
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Default Power Window Problem
The rubber around one of my windows is so tight it prevents the window from going down. You can hear it rubbing, Once thw window is about half way down its normal and it goes up normally. The other day i sprayed the inside of the rubber with WD 40 and it solved the problem but it must have dried up so its
back to the same problem. Any suggestions?
OU812 is offline   Reply With Quote
Old 11-30-2005, 12:30 PM   #2
Saturn-Eh!
Saturn-Eh!'s Avatar
Default Re: Power Window Problem
what year is the vehicle, and is it a rear window?
if it a rear, pull the weatherstrip out of the channel, and look for rust buildup which mey "pinch" the window, and slow it down. This was very common on 91-95 sedans.
Saturn-Eh! is offline   Reply With Quote
Old 11-30-2005, 01:24 PM   #3
OU812
1996 SL1
Its a 97 SW2 Front driver side window.
Old 11-30-2005, 02:08 PM   #4
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
WD-40 is NOT a lubricant, it is a water displacer. Use PB Blaster instead.
SaturnTech is offline   Reply With Quote
Old 11-30-2005, 04:10 PM   #5
Saturn-Eh!
Saturn-Eh!'s Avatar
Actually, the best "lube" for weather strips is one that is silicone based. Petrochemical based lubricants cause the rubber to swell, and eventually make things worse.
Old 12-02-2005, 02:58 AM   #6
wolfman
wolfman's Avatar
BINGO!
I hose down the channels of my power windows every fall (97 SL2) with Silicon Spray lubricant. (Prestone- Available at Walmart look for a BRIGHT YELLOW can.
They remain trouble free.
Power Window problem Askspot Aura General 10 07-27-2009 11:36 PM
Power window problem Sky King S-Series Tech 7 07-13-2008 09:23 PM
Power window problem RicSC2 S-Series Tech 3 05-21-2007 02:32 PM
Power Window Problem Oceanair S-Series Tech 2 05-15-2007 01:50 PM
Power Window Problem donnyx S-Series Tech 0 07-09-2005 02:21 PM
