Old 05-26-2005, 09:32 PM   #1
Gadweller
Gadweller is on a distinguished road
2002 SL1
Default 2002 Saturn SL1 using oil
I bought a 2002 Saturn SL1 about 3 weeks ago. It seems to be using oil. I do not know when it last had an oil change but the oil had looked ok. I noticed that the oil change soon is not on. (Should I rely on that?) I had saw about a week and a half ago that the oil was down just a little under the half area on the hatch marks and added a little less than half a quart to the crankcase. Well the oil appears to be back at that level again. I do not see any oil leaking. I do not smell burning oil. No smoke going through the exhaust. Any suggestions? Do I just need an oil change? Am I being paranoid? I need this car to be reliable. Arggggh!!
Gadweller is offline   Reply With Quote
Old 05-26-2005, 10:22 PM   #2
amazinghl
Default Re: 2002 Saturn SL1 using oil
Do a search, most older saturn uses oil. Also search for MMO piston soak.
Get a OEM PCV valve from you dealer and change it out.
Other than filling up your oil every time you fill up gas, it will probably be very reliable.
Old 05-26-2005, 10:39 PM   #3
Phonespider
Phonespider is on a distinguished road
Phonespider's Avatar
1992 SL1
Check around the bottom of your engine and the undercarrage. If there's a lot of black oily dirt sticking to things your may have an oil leak somewhere. I just got a '92 and had to replace the cam cover gasket.
Phonespider is offline   Reply With Quote
2002 SL1 Oil Leak dplemmons S-Series Tech 5 11-05-2009 01:25 PM
2002 Sl1 oil consumption and engine noise issues. Ratpack S-Series Tech 0 06-24-2009 02:11 AM
Saturn 2002 SL1 4 Cylinder ViolentCar7 S-Series Tech 4 02-14-2008 11:33 PM
2002 SL1 using oil Gadweller S-Series Tech 1 05-26-2005 10:17 PM
2002 Saturn SL1 SlapCaddle Classifieds 0 03-13-2004 11:35 PM
