Old 08-15-2004, 04:50 PM   #1
jrd_67
jrd_67 is on a distinguished road
Default clutch slave cylinder
Posted this on L series board was advised to post here.
Bought a L200 4 cyl 5 spd a year ago. On the way home from the purchase I lost the clutch. Turned out to be the slave cylinder. One year later almost to the week I am expeirancing clutch problems again. Replaced the clutch master cylinder, thinking it can't be the slave again and I find no leaks or loss of fluid. Well that did not correct the problem. Now it seems I can "pump up" the clutch and it will work for a while, but after a half hour on the interstate I am back to no pedal. Can anyone tell me is it the slave again, can't see anything else in the system that it could be. Also does anyone have a written procedure for replacing. i have seen several for S series on this site, but nothing for the L. Lastly does the bell housing need to be removed or just the trans.
jrd_67 is offline
clutch slave cylinder Q MikeNW S-Series Tech 4 04-14-2008 11:47 PM
Clutch Slave Cylinder Cheekz185 S-Series Tech 3 12-22-2007 10:19 AM
sl2 clutch slave cylinder mercad3 S-Series Tech 7 11-18-2006 11:13 PM
Clutch slave cylinder jrd_67 L-Series General 10 08-29-2004 11:16 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 12:36 PM
