Old 08-06-2008, 05:55 PM   #1
NateM137
NateM137 is on a distinguished road
Default High beams work low beams don't
Okay for the last six months my low beams have not worked. The other day I got hassled by a cop b/c I was behind him with my high beams on.
When I turn on the low beams nothing happens the DRL's stay on as if I have not turned on the lights. When I switch to high beams the DRL's turn off and the high beams turn on. I've tried replacing the fuses with no luck, I have not messed with the larger fusses, just looked at them, or messed with any relays. Any help would be appreciated.
1998 Saturn SC2
NateM137 is offline   Reply With Quote
Old 08-06-2008, 06:27 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: High beams work low beams don't
obvious question: have you checked the bulbs?
SaturnSeries.net owner
Old 08-11-2008, 10:40 PM   #3
NateM137
yes, I changed the bulbs. Also the running lights should not come on when the regular lights are on, so I think it's something more complex than just the bulbs being burnt out.
Old 08-31-2008, 01:32 PM   #4
NateM137
Okay, I think my problem may be with the alternator. Recently when I was driving at night and came to a stop the RPM's would dip really low. When I turned off the headlights the problem went away. Do you think they could be linked?
Old 08-31-2008, 03:44 PM   #5
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
In the Underhood Fuse box, pull out the DLR relay. see if that makes a difference.
Also check the wiring at the headlights, it can get chaffed and cause problems.
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
rickystarshine is offline   Reply With Quote
Old 09-01-2008, 05:10 PM   #6
NateM137
I pulled the DRL relay and fuses both in the underhood fuse box and in the cabin fuse box, it didn't work.
I also checked the wiring around the lights and it did long look chaffed or anything.
Low beams on with high beams mod aaron7 S-Series Mods 12 07-10-2009 12:06 PM
96 SC2 headlights pop up, hi beams work, lo beams don't pantero21 S-Series General 5 05-06-2006 04:46 AM
Old topic but ??? on high/low beams Son93SL2 Miscellaneous Tech 21 06-18-2001 08:47 AM
HIGH/LOW BEAMS GOTTAGO S-Series Tech 17 01-02-2001 11:03 AM
high/low beams run at same time?... LI 350 Miscellaneous Tech 2 08-09-2000 01:12 AM
