Old 04-02-2012, 04:40 PM   #1
93SC2'in
93SC2'in is on a distinguished road
93SC2'in's Avatar
1993 SC2
Dizzy blew upper rad hose now runs cooler?
this is on the 95 sl2 btw 175k
ok so the other night my upper radiator hose burst a nice 3 inch long split right at the bend next to the outlet on the head ..
anyway as far as i know its the original 95 hose so i can't complain and i did notice it starting to balloon a bit where it split so i knew it was coming rescue tape and some coolant i kept in the trunk got me home..
up until that point my car would heat up to 3/4 and kick on the cooling fan fairly quickly at an idle in traffic or moving slowly since it doesn't have the air dam. now after replacing that hose i have noticed it rarely will go above the little above 3/8ths mark unless im idling for an extended period of time. would an old about to fail hose cause it to run hotter?
the coolant that was in the car was a proper 50/50 it was less than 10k old new thermostat and new ects at the same time and the water pump has less than 5k on it.
93 SC2, 5-speed, <dead and gone>
95 SL2 5-speed, oem header, gsi TB, sprint 2.0, kyb gr2's, wb02, SAFCII, CAI, 17"s
Speed Kills - save lives, Drive a honda
93SC2'in is offline   Reply With Quote
Old 04-02-2012, 05:00 PM   #2
Default Re: blew upper rad hose now runs cooler?
Ok, you asked for it.............http://www.grc.nasa.gov/WWW/k-12/airplane/aboyle.html. Pressure, temperature, and volume. Go figure.
VCX NANO
Old 04-02-2012, 05:14 PM   #3
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
Hows that work?
Coming out of the head, the coolant has V1, P1, and T1. Going into the bubble, V1 decreases to V2, P1 increases to P2 and T1 im assuming increases to T2 since the only way that this bubble causes a decrease in cooling performance is if its causing the coolant to evaporate after it leaves the bubble, decreasing in pressure once its back into the regular diameter of the hose.
*edit, where V is velocity
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
AlexofNazareth is offline   Reply With Quote
Old 04-02-2012, 05:28 PM   #4
Ahhhhh, rocket science..........................not. Just physics. You do the analyzing. I'm done...............
Oh and there's no velocity going on here. This is a plain jane cooling system. Trying to inject velocity becomes a real engineering exercise.
When volume changes......................
VCX NANO
Old 04-02-2012, 05:42 PM   #5
AlexofNazareth
2002 SL1
2006 VUE Red Line
To be more specific, its fluid mechanics, and assuming an incompressible fluid at steady state, Boyles law has nothing to do with any property of the fluid.
Like before, any increase in volume causes:
1)Decreased Velocity
2) Increased pressure
i.e. the venturi effect.
and when it goes back into the regular diameter of the hose,
1)Pressure decreases
2)Velocity increases
I only know theoretical fluid mechanics, so what really causes the evaporation of the coolant?
*edit
called a friend. It slows the coolant flow down enough to inhibit cooling. Theres no evaporation.
'06 Vue RL
Old 04-02-2012, 05:57 PM   #6
As I said, you do the math. Fluid mechanics? Its still a low level cooling system with an old hose, maybe more than one. Use the facts given to you and let go of the strangle hold on the text book study and correlate facts with what you think you know. I'm not doubting what you know but square pegs don't fit into round holes. Temperature, pressure, and variable volume. Its all there. Nothing new to invent. Just some thinking. Not too much. Just some.
VCX NANO
Old 04-03-2012, 06:58 PM   #7
93SC2'in
93SC2'in's Avatar
1993 SC2
I would be surprised if the small area of the hose that was a little swelled, I suppose "ballooned" was a little exaggerated could cause that much of a difference in operating temps.
But if the hose was seeping a bit or releasing pressure it would reduce the boiling point and possibly causing the increase in temps? lol i'm no rocket scientist, So i'm just guessing no need to get too technical or into a heated debate or argument.
Old 04-03-2012, 07:13 PM   #8
My old '93 SL2 ran cooler after I 5spd swapped it (had a super fancy 0spd automagic) and removed A/C at the same time. Still got what I thought was great mileage at the time so I didn't think to much about it.
Old 04-04-2012, 05:00 AM   #9
93SC2'in
93SC2'in's Avatar
1993 SC2
well obviously, If it was a complete a/c removal you took out the condenser and that improved the flow to the radiator so that would probably explain your situation.
Transmission Cooler Hose tinsley207 S-Series Tech 5 02-01-2011 12:21 PM
Lower Trans cooler hose sousa632 S-Series General 4 07-22-2010 12:36 PM
Transmission cooler, which hose to use? leogag1 2008 Vue 2 07-13-2010 01:27 PM
I blew a brake hose! Sweet! 98greenSC2 S-Series Tech 24 02-10-2006 12:03 AM
Wow! I got lucky! My upper radiator hose blew! TIMSPEED S-Series General 11 02-02-2006 12:40 PM
