Old 05-31-2008, 01:36 PM   #1
hein
hein will become famous soon enough
1995 SW2
1998 SW2
Default Bleading Clutch Cylinder System
I know it's supposed to be factory sealed but I took it apart anyway. Is the disk in series between the master and slave some sort of accumulator or pressure damper? Haven't figured that one out yet. I've also been considering ways to bench bleed air from it when I put back together. Thanks for sharing your knowledge.
hein is offline   Reply With Quote
Old 05-31-2008, 11:24 PM   #2
BarnOwl
BarnOwl's Avatar
2000 SW2
Default Re: Bleading Clutch Cylinder System
What does that mean? There is a damper in the clutch hydraulics. I don't try to bleed this system but, if I were to try, this is how I'd do it.
Old 05-31-2008, 11:40 PM   #3
MikeNW
MikeNW's Avatar
1997 SL
It is a "damper". I asked this a few weeks ago- it reduces vibrations somehow. I haven't got around to cutting my spare one open to see what is inside it.
There is a way to "bleed" the system, per the post above.
Also, try a Mity Mite to vacuum air from the M/C, using suitable adapters, this was also a TSB that someone quoted.
08 Burgman 400
Old 05-31-2008, 11:45 PM   #4
MikeNW
MikeNW's Avatar
1997 SL
Check the "How To" section of this site.
08 Burgman 400
Old 06-03-2009, 01:46 PM   #5
mrclean92124
mrclean92124 is on a distinguished road
1996 SL2
Bleed Sealed master/slave in-car with no mess!
Originally Posted by 00 SLow View Post
I just finished going through hell chasing clutch problems after blowing a hole in the side of my bellhousing. After seeing lots of useful info about clutch related issues in the forum, I thought posting the directions that came with my new hydro assembly would be a be a useful addition. It's clean, dry, and doesn't require disassembling the slave.
I found it easier to bleed with the whole thing installed, with the slave hanging off the trans.
--- Twist the slave cylinder off the transmission, and point it vertically, with the pushrod facing the ground. With the cap off the reservoir, SLOWLY depress pushrod into the cylinder about an inch while watching the reservoir for bubbles. Repeat process until air bubbles no longer appear, usually about 10 to 15 strokes. With the cap still off, slowly press the pushrod in far enough to reconnect the bands on the retaining strap, if not already broken. Reinstall slave and replace the cap. Using short quick strokes, press the clutch pedal 20 to 30 times or until pedal is firm. Under normal usage, small anounts of air remaining will purge itself from the system. ---
mrclean92124 is offline   Reply With Quote
clutch slave cylinder Q MikeNW S-Series Tech 4 04-14-2008 11:47 PM
Clutch slave cylinder jrd_67 L-Series General 10 08-29-2004 11:16 PM
clutch slave cylinder jrd_67 L-Series Tech 0 08-15-2004 04:50 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 12:36 PM
Bad clutch or clutch master cylinder? speedy45 S-Series Tech 4 06-17-2002 01:35 PM
