Old 07-28-2009, 08:53 PM   #1
MikeAR
MikeAR is on a distinguished road
Dizzy New to the forum looking for some help.
I have to start off the story leading to this problem
Last november I started having major electrical problems only being able to drive my saturn SL2 about an hour before the battery was toast. process of elimination I replaced the alternator and battery and cables. The altenator shorted out took out the battery. But still the battery would not hold a charge. So after tracking down all the wiring and checking I found a lot of BURNT wires after replacing them the car now holds a charge................
Took it to the gas station filled it up and went home about 3 miles away. as I was driving my gas gauge was dropping fast!!! I lost 1/2 tank of gas just trying to get home.
I tracked the problem to a piece that NO ONE knows what it is.
On the back side of the engine by the fire wall There is a controler of sorts that one fuel line plugs into and a what I guess is a vacuum line also plugs into *that line goes back up to the air intake on top the engine*. It sits on a bracket and what I think is the MAP sensor plugs in right beside it. Does anyone know what this thing is???? I tried to put a smaller piece of gas line on it. and use hose clamps but the piece is broke off so there is not enough length on the piece to attach it where it wont come off.
None of the parts houses around me know what it is and when I called the parts department for saturn they told me they dont know what it is to bring it in. after explaining it to them that I could not drive it 1 1/2 hours to their location they told me that they would research it. that was 2 days ago and they still do not know what it is. ** go figure LOL*
So can anyone help me out and happen to know what this stupid little piece on the car that keeps making me drive my 89 towncar getting 10 miles to the gallon ;-(
I really would like my 40 MPG back LOL
Thanks in advance and sorry this was so long.
Michael in Arkansas
MikeAR is offline   Reply With Quote
Old 07-28-2009, 09:00 PM   #2
westwind999
westwind999 will become famous soon enough
1999 SW1
Default Re: New to the forum looking for some help.
Welcome
A picture would help. Model year would help too.
westwind999 is offline   Reply With Quote
Old 07-28-2009, 09:04 PM   #3
MikeAR
its a saturn sl2 1.9 DOHC manual and working on the picture now. itll be just a second on it .
Mike
2001 saturn SL2 175000 miles New alt. battery, and cables,
Old 07-28-2009, 09:31 PM   #4
MikeAR
number 1 is where the gas line goes in and 2 is the vacuum hose that goes up to the air intake and 3 is some sort of electrical connection to the part.
Thanks again for any help
Mike
Old 07-28-2009, 10:47 PM   #5
ssicarman
ssicarman's Avatar
Cannister purge solenoid.
If you have liquid fuel at it your problem is not originating at the solenoid. It is at the fuel tank. It is supposed to handle fuel vapour from the fuel tank not liquid fuel. Stop gap measure would be to unplug the vacuum line and block it and the solenoid fitting.
You do need to find out why you are gettinig liquid fuel to the solenoid though.
Old 07-28-2009, 11:20 PM   #6
MikeAR
I bow down to you my friend! ! ! ! ! ! !
Thank you so much. Now to check some more things out and see if I can find out why the liquids coming through!
I have noticed with this car its been one thing after another. but for some reason I cant let it go like I have other cars. If I had this much trouble out of a different car it would go away ASAP. but this one has me hooked on it for some reason LOL
I will let you know if I can find out something on the liquid or where its coming from anyway.
again I thank you. I searched the part you said and its only about 30$ to replace.
Mike
Old 07-29-2009, 08:31 AM   #7
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
One word on the connections of the purge solenoid.
There should not be a connection directly to the fuel tank.
The tank vent line runs to the charcoal cannister in the front right behind the bumper. Then the canister purge line runs to the solenoid, and the solenoid to the manifold.
If for some reason the tank vent line has been re-routed directly to the purge solenoid, you have found the problem.
Get a diagram of the routing for the tank vent and purge solenoid, most of this is on the rad header label under the hood, and confirm that the lines are run properly. Then look at replaceing parts.
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
mattelderca is offline   Reply With Quote
Old 07-29-2009, 08:46 PM   #8
ssicarman
ssicarman's Avatar
I believe that MikeAR's 2001 will be different than what you are thinking with your 98 and 97. If I remember correctly the vapor cannister is at the back of the car. It is certainly not at the washer bottle like on yours. On his there will be a vapor line from the rear. Either way something is feeding liquid fuel into the EVAP vapor system.
New to the forum Triforce S-Series General 7 03-19-2008 10:08 PM
New to forum DeeDeesDay 2008 Vue 2 02-21-2008 04:17 PM
New to the forum FiZuR S-Series Mods 1 04-06-2005 08:23 PM
Why I like this Forum beensmoked L-Series General 0 04-03-2005 11:52 PM
Why are there Polss in this Forum and not in (also in) The "Polls" Forum? coolgreany Community Center 6 11-06-2003 01:53 AM
