Old 07-26-2008, 12:35 PM   #1
HermTDI
HermTDI is on a distinguished road
Default Front end noise
Car Info: 1994 SL-2
Eng: 1.9L DOHC
Transmission: Automatic: MP7
Discription of symptoms:
I feel and hear a dull knocking noise eminating from the left front area of the car.
This noise stops if I lightly apply breaks or accelerate speed.
The noise is only evident when the car is crusing and there is no load.
As if I'm on a straight & level surface at 45 MPH and I take my foot off of the accelerator the noise is pronounced. At this time if I apply either power (accelerate) or break the noise will fade away.
Is this a CV joint?
I do not think it is wheel bearing related because there is no noise (of any type) when under power or when slowing (de-celerating) to a stop.
Is there a thread on how to replace a left (driver's side) drive axle?
Thank you,
Herm
HermTDI is offline   Reply With Quote
Old 07-26-2008, 12:46 PM   #2
Default Re: Front end noise
Have you done this test yet? Roll down both windows one at a time, and by moving your head closer to one open window or the other see if you can locate the sound. A bad CV joint normally makes more noise when you are making a low speed turn. Try a big parking lot and turn a couple of left hand and right hand circles.
Are the lug nuts tight on the wheel?
Old 07-26-2008, 01:40 PM   #3
HermTDI
Originally Posted by OldNuc View Post
Have you done this test yet? Snip.....snip...snip
Upon further inspection I found three (3) lub nuts in the captive recess' of the hub-cap. There was only one lug-nut actually retaining the tire/wheel assembly.
Installed all four (4) lug nuts and torqued to 87 Ft lbs.
I've already placed an order to purchase a full set (16) of new lug nuts.
OldNuc.....Thank you for your insight and assistence
Herm
Old 07-26-2008, 02:59 PM   #4
You sometimes learn from experience. I had a wheel come off because the nuts backed off. I remember the sound. It was a long time ago and I would rather not hear it again. The torque value for those nuts is 100 ftLb. That might be why they came loose.
Front end noise opsinator Vue Tech 0 02-06-2006 01:56 PM
Noise from front end? JDub99SL2 S-Series Tech 3 08-26-2003 03:07 AM
noise from front end silverblue02 S-Series General 1 07-23-2003 08:54 AM
front end noise Yobos4vr Miscellaneous Tech 2 03-23-2002 08:54 AM
Front end noise Case93sc2 S-Series Tech 1 11-27-2000 09:56 PM
