Old 07-26-2011, 04:51 PM   #1
showtime757
showtime757 is on a distinguished road
Default BCM Failing on 2003 L300 V6
Hey everyone, just registered here but I have been reading through topics on this forum for a few weeks due to an issue I'm having on a Saturn L300. I was hoping someone here could give me some good advice.
The symptoms started with the check engine and service lights randomly coming on and off, and sometimes turning themselves back off on their own while driving. A computer reading showed that we had 2 bad O2 sensors (both upstream) and multiple misfiring. Well we changed both sensors, and it cleared. The car was recently tuned up, but I have a feeling the mechanic screwed up on the spark plugs which is why we're getting the misfire. The car sometimes doesn't pick up speed normally, which could be due to the misfire.
Now for the good stuff... The car's dashboard gauges and lights (all of them), internal lights, headlights and automatic locks, sometimes do not work when the engine is started. That's if the engine starts at all. I've found that the engine will start fine and everything will turn on as long as it's night time or it's cool outside. But in the middle of the day on a hot day, there's no chance. I might be able to get the engine started, but the gauges on the dashboard and everything else mentioned above won't come on. This keeps me from being able to put the car in drive. While driving at night, the headlights and internal lights and gauges sometimes reset, causing them to flicker. And the security light on the dashboard is almost always on. Oh, and sometimes the gas gauge reads incorrectly.
We took it to a local auto electric shop, and they said the BCM is failing and quoted about $900 to fix everything... Wait, what? NINE HUNDRED DOLLARS? Obviously, now I'm looking for a cheap fix. I'd like to just be able to order the part and have somebody I know change it, but nobody seems to carry them, and I'm unsure which part to get even if I did find it. Any information or advice here would be greatly appreciated. I see a lot of you have similar issues, and I just wonder if anyone has some good advice on how to go about getting this car fixed at an affordable price without having to refinance or taking other drastic measures. Thanks in advance!
Josh
Add to showtime757's Reputation
Rate the quality of this post and help showtime757 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
showtime757 is offline   Reply With Quote
Old 07-27-2011, 07:00 AM   #2
walt848
walt848 is on a distinguished road
2002 L-Series 2.2L Sedan
Default Re: BCM Failing on 2003 L300 V6
Nine hundred bucks to replace the BCM is nuts! I have an 02 L200 and can get a replacement BCM (new) on line for about $252.00 total. If your BCM is located at the same place mine is, it is fairly easy to take out. Mine is sitting on top of the glove compartment box. I just took mine out to have an easier access to the area I needed to get to. I had it out in less than 30 minutes because I'm slow! I would suggest that you remove the BCM box yourself and save BIG bucks. The glove compartment box is only held in place by few screws. I Would make sure that the vehicle is "at" the place that will do the programming for you when you make the switch. Unplug the old one, plug in the new one and program it while "at" the place. Where I live in NC, any GM dealer will do the programming for about $75 (1 hours worth of labor) "IF" I do the removeal of the old BCM and install the new one. Hope this helps you make a decision on who will do all the work, etc. You should be able to do everything for less than $400.00 I'd t hink. That's a LONG way from that $900.00 quote you wee given.
Add to walt848's Reputation
Rate the quality of this post and help walt848 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
walt848 is offline   Reply With Quote
Old 07-27-2011, 10:26 PM   #3
showtime757
Thanks! I'm pretty sure it's located at the same place. I will have to take a look at it and get the part number, but the BCMs I've found online so far are no more than $150. Hopefully this fixes it. But is there anything I should check before buying a new BCM?
Old 08-03-2011, 08:43 AM   #4
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
A Saturn dealer years back quoted me about $700 for new computer and programming. I bought a OEM new Saturn L300 computer off ebay for $40 (probably 'hot'), and they did installation and programming for $135.
Unfortunately, a dealer will need to flash the memory on the computer.
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline   Reply With Quote
Old 08-03-2011, 08:57 AM   #5
You would be very fortunate to find a new bcm for that price unless its a used one.
Used bcm's cannot have their mileage changed, period. In addition to mileage retained on used bcm's, only GM can program your remote(s) to the used bcm otherwise you'll have no remote function. If you go this route you'll have to perform a relearn routine to marry the used bcm to your car. The 30-minute procedures are posted around with a search.
Old 08-03-2011, 11:10 AM   #6
hypnotize83
hypnotize83 is on a distinguished road
hypnotize83's Avatar
2001 L-Series 3.0L Sedan
Just had the BCM go out on my 2001 L300 V6. What a fiasco that was!!! I took the car to my mechanic and they quoted about $770 with tax to replace the BCM (OEM dealer part $440) and program it. Well after about 5 weeks of waiting and going thru three different nasty loaner cars, I finally got the car back.
After my mechanic couldn't seem to fix it, they sent it to a Chevy Dealer(Bankston Chevy Fort Worth, TX). It turns out that GM's software is messed up and the dealer had the same issues as my original mechanic. Their own software apparently killed 3 brand new OEM BCM's. So they actually had to get one pre-programmed from Detroit and send it out. Needless to say I'm just glad to have my car back. But now the A/C is starting to act up and we're having 110 degree days here in TX! Could this still be related to the BCM??
Add to hypnotize83's Reputation
Rate the quality of this post and help hypnotize83 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hypnotize83 is offline   Reply With Quote
Old 08-03-2011, 11:36 AM   #7
Uhh, no. The a/c is a totally separate issue. Expect a leak to be the main issue and if this is the first time for a/c problems then count this as exceptionally good service.
If the service valve caps are loose or missing their O-rings, a slow leak can cause loss of cooling. Dye was added at the factory and is greenish yellow, glows nicely in the shade and illuminates with a small uv light at night to find the source of a leak. 98% of the system is in the engine area and the remaining 2% are the evaporator coils and expansion valve in the HVAC box behind the firewall. Inspect the entire system otherwise a typical shop may simply say you'll need a compre$$or for no good reason other than to take advantage of ignorance. Many members post this as a typical diagnosis when its never a compressor. Its just a money maker for unscrupulous a/c shops. Half the troubleshooting is accepting that a leak has caused failure of cooling and find the source before deciding which way to proceed; repair it yourself completely or replace the faulty parts and leave the technical refrigeration work to a shop with all the equipment.
Old 08-03-2011, 12:14 PM   #8
hypnotize83
fdryer,
Thanks for the quick response! When I originally got the car back from the dealer who replaced the bcm, they forgot to program the remotes. So up until I took it back (yesterday) the A/C was working great. Including the drive home from the dealer. There's no way that they could have re-programmed or erased the compressor control? Obviously I'm not positive that the BCM controls the A/C.
One other possible cause: the A/C fan control switch inside the vehicle is starting to go bad. When you turn it all the way to max it sometimes loses the connection and the fan will go off unless you push the switch hard so it will stay engaged. It does not do that on settings 1-3. Could that be a possible cause? Thanks for your replies.
Old 08-03-2011, 01:12 PM   #9
The automatic climate control head has failed on early L-series cars too and you may have a point. Basically when a/c is requested through the HVAC control panel, a signal is sent to the bcm that goes to the ecm to turn on the compressor. This signal is just a command so the bcm can track any a/c problems for diagnostic errors. It should not be a factor with loss of cooling. The fan control switch doesn't affect compressor ON/OFF power switching as this is done by the ecm. While automated climate controls can affect a/c operation, they're usually reliable. Seeing the a/c indicator LED and hearing the compressor metallic 'click' should mean the a/c is operating. No metallic 'click' with the a/c LED on would mean loss of refrigerant because a pressure sensor can determine excessive high or low pressure to disable the compressor to protect it and the system from damage.
Turn on the a/c and listen for the metallic click as an aural indication that the compressor is running or look at the center portion of the compressor pulley. If the center is turning then the compressor is running. If the center of the pulley isn't turning then loss of refrigerant (leak) triggered the pressure sensor to disable the compressor until repairs are made.
Old 08-03-2011, 08:32 PM   #10
showtime757
Still no luck finding a new BCM... Anyone know where to find one at a decent price? If I could just find this damn part I'd be in good shape but Google and ebay are not coming up with anything.
Also, anyone have any ideas as to why the car doesn't want to start when it's hot outside?
Old 08-03-2011, 08:58 PM   #11
After you go through all the fuses, there's still the issue of spark and fuel to check. Fuel is easier to check, by the fuel rail test valve when ignition is ON. Either a fuel pressure gauge is attached to check pressure or depressing the valve stem and expecting a spray of fuel. The pump runs for 2-3 seconds and shuts off automatically unless the engine is running. Spark is difficult to test for but the main component that has a direct bearing on ignition is the crank position sensor (CPS). Next to the oil filter. Measuring the resistance at room temperature, immersed in boiling water, and rapping it against the table a few times will duplicate heat, cold, and vibration to induce failure by opening the resistance circuit. 700-1200 ohms should be measured in all three conditions and any one reading resulting in an open circuit means a faulty cps.
Search for how a cps works.
Old 08-05-2011, 10:36 PM   #12
jazzy1986
jazzy1986 is on a distinguished road
partswebsite.com has one for $257.55, new I guess.
Add to jazzy1986's Reputation
Rate the quality of this post and help jazzy1986 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jazzy1986 is offline   Reply With Quote
Old 10-05-2014, 11:39 AM   #13
crazyonetoo
crazyonetoo is on a distinguished road
crazyonetoo's Avatar
1997 SC1
If you buy a new bcm and have GM program it do they set the mileage to what your car is supposed to read? If it reads the wrong mileage I might as well save a few bucks and buy a used one from eBay. Mine isnt really bad yet. Only problem I am getting so far is that the DRL light does not illuminate and the gas gauge is at zero all the time. I know from reading here and other places that it will get much worse with time. Someone posted info on a place that rebuilds them. Would that retain my mileage info? Thanks
- 2003 L300 with V6 and 104,000 miles -
Add to crazyonetoo's Reputation
Rate the quality of this post and help crazyonetoo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crazyonetoo is offline   Reply With Quote
Old 10-05-2014, 12:06 PM   #14
Well, if you're going to pay GM to replace a faulty bcm with a new one, why would you not expect GM to program everything correctly to include copying mileage and enable your remotes (if you have them)? You're paying for GM services to correct anything directly related to a faulty bcm. No one else can and no one has ever reported anyone other than GM having the capability to program new bcm's. No one. Used bcm's are another matter.
All used bcm's retain mileage and cannot be altered by anyone including GM. Search threads within Saturnfans and you'll see some supposedly repaired bcm's by third party repair shops. They're questionable as some members trying them either fail to follow up with positive results or never post results. I'm neither for nor against third party repairs as long as they deliver on their word. Remember, you pay what you get. Bcm's are not plug n' play electronics for PC's and have many functions integrated into car EFI systems along with diagnostic capabilities. Electronic failure comes with the territory along with additional issues related to automotive electronics 'married' to integrated systems. Most members here trying used bcm's ignore the mileage differences and loss of remote use as a compromise to having a bcm operating to allow all other bcm functions to work again. GM must program remotes to bcm's whether original or new (remotes) for those wanting remote use.
Old 10-05-2014, 12:30 PM   #15
crazyonetoo
1997 SC1
Sorry if I wasn't clear. I am wanting to save a few dollars when and where I can. I, at this point want to buy a new BCM online. Its much cheaper than a dealer. If possible I would like to install it myself and then take it to the GM dealer for mileage, remote, and options programming. The dealer would charge me hourly to physically install the BCM also. That's about $100 and hour in my area. If my previous experience with the dealer in this area holds, that would be an hour to remove glove compartment. An hour to unplug the old one and plug in the new one. An hour to re-install the glove compartment. Not all dealers are honest. The only one in my area basically does whatever they want to. What I meant was IF the dealer doesn't program the mileage to show the correct mileage for my car, I might as well buy a used one somewhere.
Old 10-05-2014, 12:34 PM   #16
crazyonetoo
1997 SC1
http://www.rockauto.com/ .... $214.79 plus core charge of $25.00.
Old 10-05-2014, 01:50 PM   #17
I'm not expert on repairs so the following are based on what I know about EFI systems. Here are some hypothetical thoughts;
  • Where does it say that an owner cannot dismantle his glove box and lay the bcm down for easy access to allow GM techs to disconnect and connect a new bcm for programming? Its your car so you should be able do whatever you feel can reduce labor charges.............
  • Where does it say an owner cannot remove and replace his bcm with a new one (with or) without putting everything back to allow GM to program it without the owner incurring labor charges of GM dismanting the glove box and reassembling it? Since the glove box provides a secure mount but no electrical grounding assurances, it shouldn't matter how GM finds the bcm. Electronic access to the bcm is thru the OBD II port for all diagnostics and programming. All GM would would do is visually see a connected bcm in full view if there are any doubts about connections. The owner assumes all responsibility of wiring issues when reassembling the bcm and glove box.
  • Its between owner and GM to determine if an owner can remove impediments to reduce labor charges. Since bcm's are sitting on top of glove boxes, there's no reason anyone can't dismantle the glove box so the bcm is readily accessible.
No one should expect a new bcm with incorrect or missing mileage when its done by GM, period.
My thoughts are mine and do not reflect GM policy. I am in the same boat you're in if I suffer bcm failure so I have to consider the same issues you're facing. Its up to you as owner to discuss what you can and cannot do with your car and what GM does that's reasonable and doesn't interfere or cause any real electrical or electronic problems to prevent GM from access to programming a new bcm without creating problems. After all, long since Saturn closed as a car company, nothing is written in stone. You do as you feel is within reason to reduce costs as much as GM feels they can gouge customers as much as they wish. "Its just business, nothing personal"
2003 saturn L300 tychaos L-Series Tech 4 09-30-2010 12:29 PM
HO2S HEATER CONTROL CIRCUIT - failing (L300) - 7/18 timacts176 L-Series Tech 3 07-21-2008 04:20 PM
Mass Air Flow Sensor Failing Again - L300 - grrr! vitomacdoc L-Series General 6 05-13-2006 07:57 PM
2003, L300, V6 hognfrog L-Series General 22 10-31-2005 05:19 PM
Just got a 2003 L300.2 DBR-Saturn L-Series General 21 11-13-2003 11:08 AM
