Old 06-22-2018, 01:52 AM   #1
Gerheardt
Gerheardt is on a distinguished road
Gerheardt's Avatar
Default Question about suspension compatibility
Since my project car (Camry 1988)is nowhere near tunable, i thought i should modify my 1995 SL2 instead. I'm thinking about lowering springs. I can find some said to be for 96-2002 but not for 91-95.
As i see by parts number on rock auto, SL2 are sharing the same parts from 1991 to 2002. Is that right? If i buy lowering springs said to be for 96-2002, would it fit a 1995?
If it fits, anybody have a comment or advice on what brand to choose?
1995 Saturn SL2
1988 Toyota Camry V6
2016 Hyundai Accent
Add to Gerheardt's Reputation
Rate the quality of this post and help Gerheardt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gerheardt is offline   Reply With Quote
Old 06-22-2018, 05:21 AM   #2
Macgyver
Macgyver is a jewel in the roughMacgyver is a jewel in the roughMacgyver is a jewel in the rough
Default Re: Question about suspension compatibility
Maybe the strut assembly is different for the 91-95 years, but I've never noticed. If you still have the OEM strut, it's probably time to replace them anyway. As far as I know, all aftermarket struts I've seen worked for the entire S series line 91-02.
Add to Macgyver's Reputation
Macgyver is online now   Reply With Quote
Old 06-22-2018, 08:08 AM   #3
There's probably a strut change that makes the '91-'95's not identical to '96-'02 but they're still compatible.
The struts are probably shot anyway, I found the S-Series to be light enough to pass the bounce test even with blown struts.
Old 06-23-2018, 02:42 AM   #4
Gerheardt
Gerheardt's Avatar
My suspension works fine. I'm only thinking about lowering springs for the looks. The handling is already safe and sporty. As i recall, the whole suspension already been replaced, i seen it in the old receipts included with the car.
So as i understand, if i command lowering springs for 96-2002, it should fit?
1995 Saturn SL2
2016 Hyundai Accent
Old 06-23-2018, 03:47 PM   #5
Saturn Night
1991-1995 interchange is for the FRONT strut cartridges.
1991-2002 is for the rear strut cartridges.
www.car-part.com shows used part interchange in the searchs.
If you are looking for lowering springs, you will want to stick with 1st Gen only sets, as the struts/coils for the front may be different on a set for 2nd/3rd Gen
Saturn Night is online now   Reply With Quote
Old 06-24-2018, 12:20 AM   #6
Gerheardt
Gerheardt's Avatar
Meh, can't find any. I guess i just won't have anything low for a while. At least the handling is already good on it.
1995 Saturn SL2
2016 Hyundai Accent
Old 06-27-2018, 09:57 PM   #7
Larry O
Larry O is on a distinguished road
I got a set from h&r for my 97 s for circle track racing
No problems or complaints. Other than I would like to cut a half coil off of thrm to further lower the car and stiffen the spring rate except lowering is messing up the roll center and bump steer.
Nobody makes corrective pieces for saturns
Add to Larry O's Reputation
Rate the quality of this post and help Larry O reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Larry O is offline   Reply With Quote
Hub Question and Compatibility dlipford370 S-Series General 8 12-28-2012 05:28 PM
compatibility question dynonacht S-Series Tech 6 06-02-2012 11:51 AM
engine compatibility question davorocks S-Series Tech 11 12-30-2011 12:47 PM
Coilpack Compatibility Question SaturnManiac S-Series Tech 11 01-24-2007 04:43 AM
Clockspring Compatibility Question WingsOfSaturn S-Series Tech 1 10-31-2006 04:54 AM
