#1 |
![]() Join Date: Sep 2008
2004 VUE 2.2L
Hi all
just wondering if I can get some help with this I am experiencng some noise from the front end of the car Its almost like a bad ball joint or some thing simmilar THE catech is it only comes in slow speeds and small bumps Totally fine on big bumps and higher speeds Any suggestions..... Thankx
'04 2.2 STD Vue '00 Cavalier |
#2 |
Hey Amar,
This noise is very normal (or a common quirk) on these vehicles unless you keep all the front end suspension parts under frequent replacement plan. Most of the time this noise is from very little play in controller arms and in many cases from the steering balljoints. I wonder if there is a dampner nut/bolt on the steering assembly that can be tightened to adjust the play in the rack and pinion assembly ( I recollect seeing one when I was working in that area on my Vue). Good Luck, Another Vue owner ![]() |
#3 |
![]() Join Date: Jun 2009
2007
This noise is most probably coming from the front struts, specifically the top plastic spring mounts. Try to lubricate with silicone spray through the openings on top of the strut dome (under the hood). Better stuff might be the T-9 Boeshield parafine lubricant suggested here by one member.
#4 |
![]() Join Date: Nov 2008
2004 VUE 3.5L
Slow speeds and small bumps.... See the thread I just posted titled "Steering Wheel: Shudder, Loose, Play...Resolution."
Bookmarks |
Front end noise | HermTDI | S-Series Tech | 3 | 07-26-2008 02:59 PM |
Front end noise | opsinator | Vue Tech | 0 | 02-06-2006 01:56 PM |
Noise from front end? | JDub99SL2 | S-Series Tech | 3 | 08-26-2003 03:07 AM |
front end noise | Yobos4vr | Miscellaneous Tech | 2 | 03-23-2002 08:54 AM |
Front end noise | Case93sc2 | S-Series Tech | 1 | 11-27-2000 09:56 PM |
