Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 10-31-2002, 09:17 AM   #1
cincysaturn
cincysaturn is on a distinguished road
Default clutch safety switch
Does anyone know if it's possible to disconnect the safety switch on the clutch? You know the thing that makes you push in the clutch to start the car. It's really just out of curiosity. I'll disconnect it if its easy to get to but my guess is it's not an easy thing to do.
cincysaturn is offline
Old 10-31-2002, 09:56 AM   #2
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default Re: clutch safety switch
I would think it is just a single pole momentary contact switch, so yes- you should be able to do it. If I may ask, how come you want to do this?
~D.J.~
OhioVueBoy is offline
Old 10-31-2002, 11:39 AM   #3
BlackBirdRacing
BlackBirdRacing is on a distinguished road
BlackBirdRacing's Avatar
Default
maybe he wants to get up one morning and forget the car is in gear and hit the starter and drive into the car infront of him.
BlackBirdRacing is offline
Old 10-31-2002, 04:31 PM   #4
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
Default
Very easy to from under the dash...............
SaturnSdn is offline
Old 10-31-2002, 05:46 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
yes. the switch is on the floor behind the clutch pedal. you could unbolt and remove it and jumper the wire so the pcm thinks the clutch pedal is pushed down. i had to replace mine once when it would randomly not work so i couldn't always start my car without jiggling it.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 11-01-2002, 03:54 PM   #6
cincysaturn
Default
Actually, I was playing with the idea of putting a remote start system in which would mean I would have to disable the switch.
Old 11-01-2002, 04:18 PM   #7
Mr.Bill
Mr.Bill is on a distinguished road
Default
Good idea especially with them cold ohio mornings
But make sure you park it in neutral every evening !
Mr.Bill is offline
Old 11-03-2002, 12:09 PM   #8
eepike
eepike is on a distinguished road
Thumbs Up
How about rewiring the switch to the stick shift, there has to be a sensor for neutral to activate the rev limiter.
This would be safer than ignoring it all together, you would have to be in neutral to start, or put the switches in parallel, so you could start in neutral or when the clutch is depressed.
Be careful of the wiring, you may want to add a isolated neutral detect switch some how.
If the clutch switch is NO / Closed with clutch, the neutral detect should be parallel and NO / Closed when in neutral. If the clutch switch is NC / open with clutch, the new switch should be NC / open in neutral, and wired in series.
eepike is offline
Old 11-03-2002, 12:30 PM   #9
BlackBirdRacing
Default
there is no neutral detect switch. The factory rev limit is controlled by the vss.
Vehicle Speed Sensor
BlackBird
Old 11-03-2002, 12:46 PM   #10
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
Heres my question. How does my ECU know when I am in 5th gear and can no longer upshift.. therefore, disabling the wonderful upshift idiot light.
~D.J.~
Old 11-03-2002, 06:33 PM   #11
eepike
Default
ther should be some way to rig a nutral detect switch, even if ther was a factory one, I would suggest puting an additional one to avoud crosing circuts.
If the rev limit is tied to vechicle speed, why does it not function if you are steping on the clutch, but in gear? (not arguing, just currious)
eepike is offline
Old 11-03-2002, 07:20 PM   #12
LI 350
LI 350 is on a distinguished road
Thumbs Up
""But make sure you park it in neutral every evening""
haha! damn that would be funny... click the start button from inside the house & see your car lurch foward down the driveway & into traffic...
LI 350 is offline
Old 11-03-2002, 07:45 PM   #13
92saturnsl2
92saturnsl2 is on a distinguished road
92saturnsl2's Avatar
Default
In a manual tranny, the rev limiter is set via the VSS (as stated before)....
If the signal from the VSS indicates speed is less than 5mph the rev limiter is set at ~4000rpm. Once you're past 5 mph, you can rev the engine to 6000 in an SOHC or 6750 in a DOHC. Pushing in the clutch makes no difference after 5mph...
Be aware that if you deactivate the clutch switch (jumpering it), the cruise control will be permanately disabled. As will your wonderful upshift idiot light (worthless IMO). There might be other components affected as well. Just a little food for thought.
If you try it, let us know how it works!
92saturnsl2 is offline
Old 11-03-2002, 10:19 PM   #14
cincysaturn
Default
Yeah, I'll probably fool around with it some in the next couple days. So it disables the cruise control? Damn. I've only used it once or twice anyways. As long as nothing too serious happens I should be fine. I could care less about the upshift idiot light. Tried pulling the bulb out but that made the ses light stay on. I'll let you all know how it goes.
Old 11-04-2002, 02:32 AM   #15
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
SOme of us have been blessed with no standing still rev limiter. I can easily turn 6K at a dead stop, while another VUE will do the "brap brap brap brap" fuel cutoff at 4K.
~D.J.~
Old 11-04-2002, 10:45 AM   #16
eRic 02sc2
eRic 02sc2's Avatar
Default
that's actually happened to someone i know. it was parked in reverse and ran into the garage door. d'oh! that's why shops won't install remote starters on manual trans cars. i park mine in reverse with the parking brake on.
eRic 02sc2
Old 11-04-2002, 08:47 PM   #17
bbriand
bbriand is on a distinguished road
Default
Actually, if its possible, wire in the switch to work in reverse (if you are looking to get rid of the feature anyway). In other words make it so the car will only start if the clucth is NOT to the floor. Everyone is so used to having the clutch in this might be a possible theft deterrant. Not one that I would personally try but something to think about.
Bill
bbriand is offline
Old 11-05-2002, 02:17 PM   #18
sfc47
sfc47 is on a distinguished road
1994 SC2
Default
why don't you just rewire the clutch switch to a toggle switch so then you can turn the switch on at night to start the car in the morning and shut it off once in the car so the cruise works. You just won't be able to shut off the cruise by hitting the clutch. This is what I was planning to do when I finally get my remote starter like I want. Just watch out I had a friend put a remote starter in a manual and forgot it was in gear one time and almost hit another car. He never used it again disconnected it the next day.
sfc47 is offline
Old 11-05-2002, 04:41 PM   #19
cincysaturn
Default
I disabled the safety feature today. What I did was i cut of a piece of a paper clip, bent it into an arc, and connected the two terminals of the plug that plugs into the outlet on the sensor. I started the car to see if it worked and then wrapped it in duct tape. I haven't been out driving yet but hopefully nothing will be amiss.
Old 11-05-2002, 04:46 PM   #20
1993SC2
1993SC2 is on a distinguished road
1993SC2's Avatar
1993 SC2
Default
If you want to deactivate the upshift stupid person light, take off the dash and remove the bulb. That reminds me, my trunk open stupid person light is out, the one by the speedo is out :o: and I think a few others.
1993SC2 is offline
Neutral safety switch help Highmile S-Series Tech 2 12-15-2009 02:15 PM
clutch safety switch dorisSL S-Series General 23 11-23-2008 07:40 AM
Transaxle Range Switch\Neutral Start Safety Switch lonelywolf8588 S-Series Tech 2 07-20-2006 08:55 AM
Lock Cylinder and Clutch Safety Switch Questions MadAdam S-Series Tech 11 05-08-2006 11:22 AM
Neutral Safety Switch Marlin Liew S-Series Tech 7 11-04-2004 12:55 AM
