Old 11-28-2020, 10:03 AM   #1
97SL2guy
97SL2guy is a jewel in the rough97SL2guy is a jewel in the rough97SL2guy is a jewel in the rough
2006 ION-2 Sedan
Default What resistor for power UNlock wire to aftermarket alarm?
Greetings, Saturn fans! It's been a while since I've been on here, mainly because I've remedied all my past issues with my 2006 Ion. But now it's time to finally install the alarm I purchased over 6 months ago!
Back when I bought it, I went to install it and found that the power door lock drivers door switch has two wires; one black and one white. With the help of my trusty DMM, I found that the black is ground (kind of expected that) and the white is 12v when the lock or unlock button is pressed on the factory key fob. Only problem is, from what I've read, it's considered a "one wire" switch (the white being the one wire they're talking about).
So... since the alarm has TWO wires (one for lock, one for unlock), I read somewhere here in the Ion forum that you need a resistor connected between the alarm's unlock wire and that white wire in at the switch. Trouble is, I can NOT find that original post, so I'm once again baffled by which resistor to get. The person that posted it said that the switch gets a much lower voltage signal from the BCM when the UNlock button is pressed, so on an aftermarket alarm, you need to put in a resistor to tell that one white wire that you want to UN lock your door.
Can someone remind me what resistor I need? I searched on eBay back when they posted it, but I cleared my history so I totally can't find which resistor I searched for. I think it was something like a 1.5K 1/4 watt or something like that. I'm not really familiar with resistors so I had trouble finding the specific one mentioned in the forum.
Anyone ever install this resistor and get their aftermarket alarm's two wires to lock and unlock their driver's door with the aftermarket alarm remote? If so, which resistor did you use?
Thanks so much!
(I'm pretty sure this is not a repost because I had this same question 6 months ago but can't find where I posted about it here.)
Sold the 97 SL2 and bought a 06 Ion! SO MUCH NICER car! Problem is, I don't think there is a way to change my username, so I'm leaving my username alone until I figure out if/how it can be changed.
97SL2guy is offline   Reply With Quote
Old 11-28-2020, 12:35 PM   #2
ruley73
ruley73's Avatar
Default Re: What resistor for power UNlock wire to aftermarket alarm?
The wiring diagram indicates a 1.5K ohm resistor is used on the unlock side of the circuit.
2007 Chevy Equinox LT 198K miles
2018 Chrysler Pacifica Touring L 56K miles
Old 11-29-2020, 09:44 AM   #3
97SL2guy
2006 ION-2 Sedan
Thanks so much! I'm finding tons of those on eBay! Only problem now is they come in different wattage and tolerance ratings, so I'm only HALF confused now. LOL! But this is a start! I might just order different ones and try the lower rated ones first.
Old 11-29-2020, 06:29 PM   #4
ruley73
ruley73's Avatar
The resistor doesn't have to be huge. The electrical load of the power locks doesn't go through the switch like in older vehicles. It's literally just a switch that tells the BCM when the lock/unlock button is being pressed. A 1.5K ohm resistor with a 1/2 watt rating would work just fine.
Aftermarket Audio question - No power from the ignition wire KillerX Astra General 10 04-02-2009 10:47 AM
power lock + aftermarket alarm dorisSL S-Series Mods 14 11-03-2008 09:20 PM
Wire RKE to flash lights for LOCK/UNLOCK? rearviewmirror S-Series Tech 2 11-07-2007 07:44 PM
Installing aftermarket remote start ... power door lock wire? paulygon S-Series General 1 05-28-2006 09:35 PM
Can I make alarm/keyless entry system beep on lock/unlock? kmcgillivray S-Series Tech 4 09-17-2004 08:16 PM
