Old 06-04-2002, 11:12 AM   #1
Blaise
Blaise is on a distinguished road
Default Speaker Size
Ok,
I was checking to see the size of the speakers in a 1992 SL becase I am planning on changing out all the component speakers. A website (www.sounddomain.com) states that the '92 has 7"speakers in both the doors and the rear deck. Is this correct? And it also gives speakers that would be good to fit in the tailgate/pillar..... whats this? I dont have any speakers in the tailgate/pillar? What is the pillar? Help!
Add to Blaise's Reputation
Rate the quality of this post and help Blaise reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blaise is offline
Old 06-04-2002, 11:29 AM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default
the speakers in the s-series saturns are in both the doors and the rear deck are oversized/euro 6 1/2" or 6 1/2"S" or 6 3/4" depending on where you look. regular 6 1/2" speakers are slightly too small, but can be adapted to fit.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 06-04-2002, 01:54 PM   #3
Blaise
Default
Would 6x9's fit in the rear? Or would you have to cut to make them fit?
Blaise is offline
Old 06-04-2002, 01:57 PM   #4
XtremeGrandAm
XtremeGrandAm is on a distinguished road
Default
yes, you would have to modify the rear deck to fit 6X9's
Add to XtremeGrandAm's Reputation
Rate the quality of this post and help XtremeGrandAm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
XtremeGrandAm is offline
Old 06-04-2002, 02:01 PM   #5
Qlara
Qlara's Avatar
Question
Side question: Do speakers in Oval shape (6x9) sound better than over-size speakers? (10" instead of stock 6 3/4")
You need modification on the deck to fit size other than 6 3/4 anyway, why not put in the biggest you can afford?
Add to Qlara's Reputation
Qlara is offline
Old 06-04-2002, 02:24 PM   #6
XtremeGrandAm
Default
I never had to do anything to put 6 1/2 in the rear of any of our saturns. You can move them around so they fit put with 6X9 you would actually have to cut out some areas. I know most speaker companies know GM's size and make the 6 1/2 so that they will fit on GM vehicles.I dont think 6X9 are all that better but yet Ive never heard them alone without any subwoofers. So I guess I dont really know....
Old 06-04-2002, 04:26 PM   #7
steveschmitt
steveschmitt is on a distinguished road
Default
i have a 92 sl2...the front and rear are 6 1/2
Add to steveschmitt's Reputation
Rate the quality of this post and help steveschmitt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
steveschmitt is offline
Old 06-05-2002, 07:06 PM   #8
RustyJCNC
RustyJCNC is on a distinguished road
RustyJCNC's Avatar
Default 6x9's
If you're going to get a sub/amp then screw the 6x9's. You'll get the added bass from that. I swapped the factory issue speakers with Infinity's, dropped right in, no cutting.
There are plenty of other alternatives that will slip right in.
-j
Add to RustyJCNC's Reputation
Rate the quality of this post and help RustyJCNC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RustyJCNC is offline
Old 06-06-2002, 01:59 PM   #9
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default 6x9
6x9's definitely prodeuce a better bass response. I had a set of Boston Accoustics in my Accord for a while running off an amp with no sub, and it did sound as though there was a sub.. I haven't been able to pull that off with my rockford slightly higher quality 6.5" speakers in the saturn..
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
Old 06-06-2002, 02:01 PM   #10
Applefool
Applefool's Avatar
2006 ION Red Line
Default 6x9 addmendum
Also, i looked into csutom fitting my 6x9's into the Saturn, and it is just plain not worth it..
Old 06-06-2002, 09:10 PM   #11
Blaise
Default
Ok Thank you.
Blaise is offline
Old 06-18-2002, 09:30 AM   #12
97SC87
97SC87 is on a distinguished road
Default
I got FREE 6.5" speakers when i bought my deck. The holes dont line up properly.. is there some sort of adapter ring i could get? i tried to make my own but it is nearly impossible because of the curves on the bottem of the back deck in my 97sc1
Add to 97SC87's Reputation
Rate the quality of this post and help 97SC87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97SC87 is offline
Speaker size? KevSC1 Astra General 3 01-23-2008 04:20 PM
Speaker size... B|o|B|o 2008 Vue 5 01-22-2008 05:27 PM
size of speaker coliphage Miscellaneous Tech 9 07-14-2004 11:44 AM
Speaker Size Confusion MisterIon Ion General 8 02-14-2004 06:52 AM
speaker size and ?s steelers101 Ion General 39 09-20-2003 07:10 PM
