Old 07-13-2004, 09:43 PM   #1
coliphage
coliphage is on a distinguished road
Default size of speaker
This is a stupid question.
I am planning to replace the factory speakers.
But I am confused about the speaker size.
A --------B
C ------- D
"ABCD" are the position of mounting flanges. For a 6.5" speaker,
is 6.5" the distance between A&B or A&C?
Thanks
Add to coliphage's Reputation
Rate the quality of this post and help coliphage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
coliphage is offline
Old 07-13-2004, 10:19 PM   #2
savage
savage is on a distinguished road
savage's Avatar
Default
there 6.5 i just did mine today. other will fit w/ minor mods. and or an adapter from www.crutchfield.com
94 SL1 wrecked
95 SL2 New project ride. Nx wet kit, ooh yeah.
Add to savage's Reputation
Rate the quality of this post and help savage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
savage is offline
Old 07-13-2004, 10:28 PM   #3
coliphage
Default
the weird thing is that when I check crutchfield.com, it shows 6 3/4" fit perfectly, the 6 1/2" one need some mods.
when checked at circuitcity.com, both fit.
so, your 6 1/2" ones fit well?
Old 07-13-2004, 10:55 PM   #4
94sc2boy
94sc2boy is on a distinguished road
1994 SC2
Default
the sizes are all jacked up.
I put in Pioneer 6.5 which are "oversized"
So yes, 6.75 will probably fit better.
Add to 94sc2boy's Reputation
Rate the quality of this post and help 94sc2boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94sc2boy is offline
Old 07-13-2004, 11:33 PM   #5
thewretched
thewretched is on a distinguished road
thewretched's Avatar
Default
they are in fact 6.75 without modification
Add to thewretched's Reputation
Rate the quality of this post and help thewretched reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thewretched is offline
Old 07-14-2004, 01:24 AM   #6
Bigbadbert
Bigbadbert is on a distinguished road
Bigbadbert's Avatar
Default
Either will work no problem.
'01 SC2 - sold
Add to Bigbadbert's Reputation
Rate the quality of this post and help Bigbadbert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bigbadbert is offline
Old 07-14-2004, 03:01 AM   #7
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default
The size is roughly the diameter of the speaker, not the distance between mounting holes. In my 95, 6.5" speakers did not fit the stock holes, so they drilled new ones. I would either buy 6.75" or get 6.5" with adapters, if you want them to fit stock. Drilling new holes was no big deal for me, but it might make a difference if you live in a place more prone to rust (for the front door area).
Add to Heartbeat - '95 SL2's Reputation
Rate the quality of this post and help Heartbeat - '95 SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Heartbeat - '95 SL2 is offline
Old 07-14-2004, 04:43 AM   #8
freakerz
freakerz is on a distinguished road
freakerz's Avatar
Default
Simply check on the box, my pioneers said "GM 6 1/2 Compatible".
No mod! Swapped stock for pionners
Add to freakerz's Reputation
Rate the quality of this post and help freakerz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freakerz is offline
Old 07-14-2004, 09:27 AM   #9
eRic 02sc2
eRic 02sc2's Avatar
Default
the correct size is 'oversized' 6 1/2" or 6 3/4". some 6 1/2" speakers have a second set of holes to make them fit in a 6 3/4" opening but some don't. look on crutchfields size guide and they tell you.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 07-14-2004, 11:44 AM   #10
Tuanies
Tuanies is on a distinguished road
Default
6.5" Speakers with 4 mounting holes will fit without any problems.
Add to Tuanies's Reputation
Rate the quality of this post and help Tuanies reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tuanies is offline
Speaker size? KevSC1 Astra General 3 01-23-2008 04:20 PM
Speaker size... B|o|B|o 2008 Vue 5 01-22-2008 05:27 PM
Speaker Size Confusion MisterIon Ion General 8 02-14-2004 06:52 AM
speaker size and ?s steelers101 Ion General 39 09-20-2003 07:10 PM
Speaker Size Blaise S-Series Mods 11 06-18-2002 09:30 AM
