Old 04-13-2015, 12:25 PM   #1
tink65
tink65 has a spectacular aura abouttink65 has a spectacular aura about
Default mystery sensor
02 dohc
I ask only because it's not in the Chilton, and without the slightest idea of a description Google isn't doing any good.
Its an engine block sensor on the intake side, between the knock sensor and crank position sensor. Its round, maybe 3/4 inch thick, the face in contact is metal, and it through bolts to the side of the block.
What is it?
Another mystery is why do I have a bracket/brace leftover from the engine. Six inches long, one bolt on each end, twisted 90... Alternator brace? Starter brace?
Add to tink65's Reputation
Rate the quality of this post and help tink65 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tink65 is offline   Reply With Quote
Old 04-13-2015, 12:28 PM   #2
Default Re: mystery sensor
Post a picture of the sensor and it's location.
I bet the brace goes between the TB and the EGR valve.
Old 04-13-2015, 12:38 PM   #3
robb_sc2
robb_sc2 is on a distinguished road
1999 SC2
Originally Posted by tink65 View Post
02 dohc
on my 99 sc2 there is a bracket that goes from throttle body towards front of engine bay, I think to stiffen the throttle body a bit.
Gold 1999 SC2 ~385k Kms
Add to robb_sc2's Reputation
Rate the quality of this post and help robb_sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robb_sc2 is offline   Reply With Quote
Old 04-13-2015, 01:02 PM   #4
Oil pressure sender
Old 04-13-2015, 01:46 PM   #5
^ +1 ^
Old 04-13-2015, 02:53 PM   #6
tink65
Negative on oil sender. Im looking at the knock sensor, I'm almost sure of it. http://www.saturnfans.com/forums/sho...d.php?t=122196
From the description in the Chilton (no diagram of course), I had the oil pressure sender confused with the knock sensor.
As for the brace, I'm still searching. Based on all the grime, it should've come from somewhere below the tb, on the backside of the motor. There's an almost identical brace from the intermediate shaft bearing block to the underside of the manifold. I set it aside with one bolt, so one end bolts somewhere there wasn't a bolt, and the other end bolts to somewhere that has a bolt already....
Old 04-13-2015, 04:41 PM   #7
Tried using online auto parts places that show parts? Autozone, Advanced Auto, Pepboys, rockauto, etc.? A short list of sensors on that side of the engine would be; knock, oil, and crank sensor. An even faster way to identify parts if you have any nomenclature, Google and selecting images.........
Why the curiousity?
Old 04-13-2015, 05:36 PM   #8
If you are asking about the device mounted at 27, that is the knock sensor. Design for the connector changed for Gen-3.
http://www.saturnwiki.com/wiki/image...gineRear-A.jpg
Old 04-13-2015, 06:59 PM   #9
lowflyer
lowflyer is a name known to alllowflyer is a name known to alllowflyer is a name known to alllowflyer is a name known to alllowflyer is a name known to alllowflyer is a name known to all
2001 SWP
2000 SWP
if it's round like a stack of 5-6 quarters with a hole through the center, it's the knock sensor. the brace isn't to secure the fuel line by chance? a picture would solve the mystery in seconds.
Add to lowflyer's Reputation
Rate the quality of this post and help lowflyer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lowflyer is offline   Reply With Quote
Old 04-13-2015, 10:51 PM   #10
Can't on a 3rd gen DOHC, at least not the same way as 1st and 2nd gen DOHC's and 2nd and 3rd gen SOHC's.
Guessing either power steering pump brace or axle bracket to IM brace (both pictured).
Old 04-13-2015, 10:55 PM   #11
Lower plastic intake brace that is centered under the throttle body.
"Mystery" A/C switch/sensor '98 SC2 RockinFX S-Series Tech 17 02-20-2015 05:35 PM
I've got a mystery kwguy Vue Tech 6 02-15-2013 02:30 AM
Marvel Mystery Oil is indeed a mystery. KSabo S-Series Tech 40 07-07-2011 09:34 AM
Mystery Sensor Bobber S-Series Tech 1 03-14-2009 04:45 PM
Mystery sensor... triple_el S-Series Tech 4 08-22-2008 09:33 AM
