Old 04-28-2010, 09:03 PM   #1
zatherith
zatherith is on a distinguished road
Default AT swap from 97 DOHC to 2000 DOHC question
I own a 2000 SL2 DOHC automatic and I am having problems with my trans taking longer to switch from second to third, and I believe it is slipping. I acquired another automatic transmission that I know works without any problems from a 1997 SL2 that has the same DOHC engine in it and I wanted to make sure that it is compatible since both the engines are the same, and if the computer would have any problems with it.
Add to zatherith's Reputation
Rate the quality of this post and help zatherith reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zatherith is offline   Reply With Quote
Old 04-28-2010, 10:05 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: AT swap from 97 DOHC to 2000 DOHC question
Gear ratios will be a bit off..
http://www.differentracing.com/tech_...gearratio.html
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 04-28-2010, 10:14 PM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Originally Posted by adventureoflink View Post
Which could result in the PCM being unable to properly control the trans.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 04-29-2010, 12:46 PM   #4
skii33
skii33 is on a distinguished road
gear ratios are the same ... it will work ...trust me ..I put a 2000 sl2 into a 95 sl2 . NO Problems . I read on here how the gear ratios changed in 98, and only one guy on here out of all the others assured me it would work , and it did. You all can argue and say i'm wrong if you like but i know what i know
Add to skii33's Reputation
Rate the quality of this post and help skii33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skii33 is offline   Reply With Quote
Old 04-29-2010, 02:48 PM   #5
adventureoflink
not to mention wouldn't that affect the cruise control (assuming the OP has cruise)?
ALSO:
Actually you are mostly correct; the FORWARD gear ratios seem to be the same from 1991-2002, but the REVERSE ratio is a bit off though. So I apologize.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 04-29-2010, 03:01 PM   #6
zatherith
Happy Re: AT swap from 97 DOHC to 2000 DOHC question
Thanks everyone for the responses, it really helped allot
Old 09-04-2011, 03:05 PM   #7
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
I know this is an old thread but with the reverse gear ratio being different does that mean it might not go in reverse?
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 09-04-2011, 05:35 PM   #8
+1^^^He is correct, it will work.
Old 09-04-2011, 05:37 PM   #9
It will be fine in reverse unless you are attempting to drive in reverse at 6500RPM. There is a minimum speed below which the PCM is no longer interested in any mismatch with any forward gear.
If this was as critical as some think then changing tire diameter would trip you up.
And beyond that the PCM does not monitor reverse performance at all.
Engine swap: 2000 SL2 DOHC for SOHC mjm S-Series Tech 4 05-05-2009 11:13 AM
Swapped a 2001 SC1 DOHC engine with a 2000 SL2 DOHC now have transmission issues knukklhead S-Series Tech 18 04-13-2009 06:48 PM
2000 dohc to 1999 sohc swap? tc6160 S-Series Mods 4 02-01-2009 09:36 PM
considering a 2000 SOHC to DOHC swap justinkennedy S-Series Tech 17 10-25-2008 12:06 PM
Swap 2000 SL2 DOHC (auto) into a 1999 DOHC (manual)? kim_lombard S-Series Tech 3 02-22-2008 12:12 AM
