Old 07-16-2019, 11:04 AM   #1
Tyson
Tyson is a jewel in the roughTyson is a jewel in the roughTyson is a jewel in the rough
2002 L-Series 3.0L Sedan
Default Clunking and rattling front and back 2002 l300
I replaced both ball joints and control arms in front of 02 l300. I am still hearing considerable clunking and rattling in front and rear. Can anyone tell me what I should start with. Quick strut assembly is a must along with a new stabilizer bar for both sides. Would that fix the front end? Then I need answers for the rear. Thank you
Add to Tyson's Reputation
Rate the quality of this post and help Tyson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tyson is offline   Reply With Quote
Old 07-16-2019, 12:02 PM   #2
Default Re: Clunking and rattling front and back 2002 l300
Why didn't you state this in the post regarding "Very loose steering?" Tyson, your steering problem and what you're discussing here are to some degree related. Avoid creating too many thread over related problems, it's not helpful.
There is only ONE stabilizer bar, not a separate bar for each side. Do you mean the stabilizer links? Another member's recent experience with quick struts should be considered. He found them unsatisfactory as they pushed the car's height higher than it was prior to their installation.
I've never had unusual front or rear axle suspension noises on my car. Were the control arms installed correctly, tightened to factory torque specs, and with new bushings?
Have you examined the rear axle suspension? Look closely at the two bushings connecting the upper and lower rear control arms to the knuckle directly behind each rear wheel's brake backing. Some members have complained of clunking noises coming from this area and ending after the bushings had been replaced. These bushings are not traditional solid rubber parts. They are fluid filled and eventually burst and they then partially expose the steel shaft on the inside.
Where should you start to correct the clunking noises, front or rear? Take your pick. What matters most is an accurate diagnosis after examining all of the suspension components.
313,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 08-13-2019, 07:03 PM   #3
Chaz9496
Chaz9496 is a jewel in the roughChaz9496 is a jewel in the roughChaz9496 is a jewel in the rough
2001 L-Series 2.2L Sedan
2003 L-Series 2.2L Sedan
I have the same problem Tyson. I can't find it either. Everythings tight, including new strut mounts.
Add to Chaz9496's Reputation
Rate the quality of this post and help Chaz9496 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chaz9496 is offline   Reply With Quote
Old 08-14-2019, 12:14 AM   #4
On level ground, crawl under and try shaking the rear torsion bar. The outboard rubber isolation bushings may have hardened and shrunk, allowing the bar to rattle.
Old 08-14-2019, 01:04 AM   #5
Hmm...a rear torsion bar? I've not heard of those on the L-Series, but I could be misunderstanding things. Do you mean trailing arms (as they do mount longitudinally like a torsion bar would) or the sway bar?"
2002 l300 3.0 steering wheel clunking bad mrhappypantz L-Series Tech 7 02-19-2016 05:31 PM
Update on rattling/clunking noise front end Dennis6 2008 Vue 42 04-24-2014 04:34 PM
Most likely rattling/clunking noise? wy2sl0 S-Series General 4 03-25-2010 12:10 AM
Constant rattling/clunking noise cola S-Series Tech 11 04-23-2009 05:43 PM
2002 L300 headlights flash off then back on robertobates L-Series Tech 0 02-18-2008 07:20 PM
