Old 07-18-2019, 09:34 AM   #1
mdbrill
mdbrill is on a distinguished road
Default Running A/C without A/C diode in fuse block.
Hello,
I recently diagnosed an issue with my A/C fuse constantly blowing. I figured out that it was the AC diode that goes in the fuse block. With it out, the compressor runs great and no more fuse popping. I ordered a new diode. Can I run my A/C without it, until the new one comes in the mail, or is that too risky?
Add to mdbrill's Reputation
Rate the quality of this post and help mdbrill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mdbrill is offline   Reply With Quote
Old 07-18-2019, 10:06 AM   #2
Default Re: Running A/C without A/C diode in fuse block.
Can you find one locally?
The diode is there to protect the rest of the cars electronics from an induced voltage surge when the clutch is de-energized.
A diode is basically a one way valve for electricity, the normal power can pass through to energize the coil, but the induced backflow voltage is blocked. Your computer needs protection from such a surge, as they are very sensitive to it.
Old 07-18-2019, 10:28 AM   #3
I would not. Besides computer stuff you will fry your relay and expose the clutch circuit to big voltage spikes.
Add to Waiex191's Reputation
Old 07-18-2019, 11:17 AM   #4
You will only do it a couple of times.
Any decent parts store has them or any Chevy dealer.
Old 07-18-2019, 02:45 PM   #5
Post Re: Running A/C without A/C diode in fuse block.
Go to a junk yard and you'll find them in fuse boxes. Pick a GM model, any model and pull the diode out for your car. If you find a Saturn, pull the diode out as the closest match.
@#%& underhood fuse block brokendown S-Series General 4 01-25-2016 12:16 AM
01 Fuse Block Diagram grabemandgo S-Series Tech 1 03-26-2015 09:40 PM
Fire in my fuse block velleguy73 S-Series Tech 4 07-06-2011 09:20 PM
Does fuse block from 96 SL fit 95 SL projectpete19 S-Series Tech 9 07-26-2008 02:38 PM
engine fuse block softspot S-Series Tech 1 03-01-2006 12:54 AM
