Old 11-10-2007, 01:33 PM   #1
storm_amoure
storm_amoure is on a distinguished road
2006 ION-2 Quad Coupe
Default p0410 code
my check engine light came on so i read the codes and i get the p0410 reading secondary air injection system malfunction.. any ideas
Add to storm_amoure's Reputation
Rate the quality of this post and help storm_amoure reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
storm_amoure is offline   Reply With Quote
Old 11-10-2007, 02:06 PM   #2
storm_amoure
Default Re: p0410 code
Another thing is too i have trouble with my coolant bottle which that brings on my coolant and temperature lights would that conflict with the p0410 code too? i also replaced the tts sensor and the etcs sensor with in the past 2 months
Old 11-10-2007, 02:40 PM   #3
eljefino
eljefino's Avatar
1995 SW1
If you jammed a wire or hose at the pump then yeah.
The AIR injection system only runs over a specific range of intake temperatures (40-70'F IIRC) at cold startup, so if you jammed something a while ago conditions may have only recently become just right for the system to run.
Add to eljefino's Reputation
Old 11-10-2007, 03:12 PM   #4
storm_amoure
so you tink if i change the coolant bootle it may get rid of code i checked all the vacuum hodes and thet look good
P0410 error code - HELP mx103 S-Series Tech 10 11-20-2012 09:49 AM
P0410 Error Code pgp_protector S-Series Tech 5 08-18-2009 11:12 AM
Persistent P0410 code 99 sc2 ken4jd S-Series Tech 2 02-08-2009 12:54 PM
Throwing code P0410 Mike88 L-Series Tech 0 09-23-2007 10:40 PM
Code P0410 Yellow Hornet S-Series Tech 2 01-25-2005 10:25 PM
