Old 01-04-2004, 05:55 AM   #1
ecaryn
ecaryn is on a distinguished road
ecaryn's Avatar
Default EGR code P0405
The Service Engine Soon light came on on my car for about 5 seconds before I shut it off. Left the car off for a few days until I could take it to Autozone to have it scanned. Drove to work and then Autozone after work but light never came on again. Autozone scanned code P0405 for the EGR valve. This was about two weeks ago and light has never came back on, car doesnt run any different. My owners manual says that something as simple as bad gas can cause the SES light to come on. Since the light has not been back on do you think that could be the case in my situation? How could I check to be sure the EGR valve is actually bad since light has not come back on? What about the solenoid, could it be the culprit and how would I test that? Thanks for any help.
1996 SL2 DOHC
Add to ecaryn's Reputation
Rate the quality of this post and help ecaryn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ecaryn is offline
Old 01-04-2004, 10:09 AM   #2
TedL
TedL is on a distinguished road
Default
Thgis code means the feedback voltage is out of range, high or low. The FSM gives several diagnostic aids, but the simplest suggestion: Carbon may be blocking EGR pintle movement.
You could have blown away whatever, if that was the cause. Try getting a new gasket and then gently cleaning the EGR. A couple bucks and less than an hour invested, even if that's not the real cause.
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 01-04-2004, 10:35 AM   #3
eljefino
eljefino's Avatar
1995 SW1
Default
You can typically reuse the EGR gasket.
Add to eljefino's Reputation
eljefino is offline
p0405 egr problem ifried85 S-Series Tech 3 07-25-2009 02:52 PM
Getting P0405 - where is the fuse for the EGR? OnMy4th S-Series Tech 1 06-15-2009 10:30 AM
P0405 EGR engine code help needed btbell0615 S-Series Tech 3 03-05-2008 12:42 PM
P0405: EGR going out? 98greenSC2 S-Series Tech 0 05-13-2006 10:22 AM
SES help: P0405 on a 99 SC2 - EGR? abkaiser S-Series Tech 8 04-07-2004 02:07 AM
