Old 11-23-2007, 11:37 AM   #1
rgierer
rgierer is on a distinguished road
Default failed emissions code P0405
The car 1998 SL2 with 168,000 miles. This car has just come to me. My first task was to replace the alternator. I sill need to put the wires back on the power steering unit.
I took it for inspection this morning and it failed emisions with the P0405 EGR sensor A circuit low.
I have driven the car less than 10 miles since I replaced the alternator.
I can take the EGR off and clean it, but I don't have symptoms I can point to so before I start I am asking for a little help from those ever so much wiser than me.
Robin 1998 SL2
Add to rgierer's Reputation
Rate the quality of this post and help rgierer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgierer is offline   Reply With Quote
Old 11-23-2007, 11:51 AM   #2
yazhere
yazhere is on a distinguished road
yazhere's Avatar
Default Re: failed emissions code P0405
Here's a prior thread for you to read... but in a short.. clean the EGR to make the pintle seat fully..
http://www.saturnfans.com/forums/sho...ighlight=P0405
This is an interesting read also:
Add to yazhere's Reputation
Rate the quality of this post and help yazhere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yazhere is offline   Reply With Quote
Old 11-23-2007, 04:11 PM   #3
rgierer
I pilled the EGR and cleaned it with carb cleaner. I put it back on the car. I noticed there was a vacuum line runing to a sensor. There are no wires attached to the sensor. I went to autozone and had my codes checked. No change.
I suspect my problem is tied to the lack of wires going to the sensor.
I am asking for guidance as to where I might find them.
Please be apprised. This car belongs to a friend of my daughters. She has said she is selling it to me but I have yet to see a title. I obviously have no manual at this point.
Robin 1998 SL2
Old 11-23-2007, 06:02 PM   #4
rgierer
I have pulled off the sensor. As it was in the car it had a vacuum hose running from the sensor to the egr and nothing atached to the other end. There is a place for a pulg but I have searched high and low and am finding nothing.
Right now I am truly open to suggestion.
Robin 1998 SL2
Old 11-23-2007, 08:31 PM   #5
WingsOfSaturn
WingsOfSaturn's Avatar
Your EGR is electrical, should not be any vacuum lines going to it. Maybe post a picture of what you are talking about.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 11-23-2007, 08:44 PM   #6
rgierer
I will try to take a picture of the egr and the sensor. It is different than the egr in the how to section
Robin 1998 SL2
Old 11-23-2007, 09:18 PM   #7
rgierer
I went to autozone and looked at an EGR for a 1998 SL2. It is not like my EGR. The sesnor and the EGR are 1 integrated unit w/o vaccum lines.
It causes me to wonder if this car didn't have a problem in the past and has an older head put on it with an older egr.
I have located a blue elongated plug in that may fit the appropriate EGR. My next and most obvious question is whether or not the correct EGR will bolt onto the intake.
Any ideas?
Robin 1998 SL2
Old 11-23-2007, 09:33 PM   #8
yazhere
yazhere's Avatar
Sounds like the older EGR.. 1994 and earlier.
Old 11-23-2007, 09:49 PM   #9
rgierer
Do you think the newer EGR will bolt up to the intake?
Robin 1998 SL2
Old 11-23-2007, 09:56 PM   #10
yazhere
yazhere's Avatar
Take that picture for us. We are as confused as you are. If you are saying that you have a 1998 Saturn and the EGR valve taken off has a vacuum hose running to the top of it instead of electrical connections, you have a mongrel.
Old 11-23-2007, 10:12 PM   #11
yazhere
yazhere's Avatar
Which one do you have?
1.http://www.saturnfans.com/photos/sho...hp?photo=20099
2. http://www.saturnfans.com/photos/sho...hp?photo=20069
3.http://www.saturnfans.com/photos/sho...hp/photo/26612
Old 11-23-2007, 10:59 PM   #12
rgierer
I believe 20069
Robin 1998 SL2
Old 11-23-2007, 11:07 PM   #13
If you have the EGR valve in the second and third pictures then you don't have a 98 and could not have gotten the P0405 code. What is the tenth digit of the serial number?
Add to ssicarman's Reputation
Old 11-23-2007, 11:22 PM   #14
rgierer
vin 1G8ZK5275WZ159099
Robin 1998 SL2
Old 11-24-2007, 01:02 AM   #15
The serial number you gave indicates that you have the 98 MY. The code you gave is good for 1998. You saying that you think that you ave a vacuum EGR is not right for a 98. Your EGR should look like the one in the first picture just to the left of the black bracket on the cylinder head and above the AC Delco box.
I think that at this point you should try to get us a picture of what you think is your EGR and the sensor that you are talking about.
Old 11-24-2007, 10:46 AM   #16
rgierer
I am hoping the photo attached. I may need to try again.
Robin 1998 SL2
Old 11-24-2007, 11:23 AM   #17
BarnOwl
BarnOwl's Avatar
That's not a '98 EGR valve. It's also not a '98 engine. At least, the cam cover's not a '98. Starting in '96 the cam covers are black plastic. At best it's a '94 engine or someone swapped in a pre-95 head. After '94 you couldn't put that EGR on the head. To do that in a '98 would take some work. Low Saturn would know what it would take but, you definitely have a frankenstein on your hands. You mention a P0405. That's an OBD2 code. Saturn never made an engine with that EGR valve that had an OBD2 PCM. That may be the problem with the light. However, I think you have other problems. Where did you get this car? How long have you had it?
Add to BarnOwl's Reputation
Old 11-24-2007, 11:36 AM   #18
rgierer
I can only say I don't yet own the car. So I know very little about it.
But apparently lowsaturn is where I need to go
Robin 1998 SL2
Old 11-24-2007, 12:00 PM   #19
BarnOwl
BarnOwl's Avatar
I'd take it for free but, I wouldn't buy that car without a lot more info about it's history.
Old 11-24-2007, 12:08 PM   #20
yazhere
yazhere's Avatar
By looking at the photo, it appears that the head is post-95 since there is only the "unconnected" ECTS.
The OP indicated there is wiring nearby for the necessary EGR.
How about a photo of those connectors?
It may be that the person selling this Saturn doesn't know the differences in Saturns and thought that any type EGR would work.
Code 26 back again - failed emissions striider S-Series Tech 18 12-29-2009 07:48 PM
Help! My 1999 SC2 failed emissions! Trouble Code P0440! djmikeyz28 S-Series Tech 3 05-09-2009 12:21 AM
Failed Emissions poorboy S-Series Tech 8 02-21-2009 02:57 PM
HELP!! Emissions FAILED!! misterspigot S-Series Tech 9 02-19-2007 06:27 PM
EGR code P0405 ecaryn S-Series Tech 2 01-04-2004 11:35 AM
