Old 01-04-2019, 06:10 PM   #1
SolomonMan
SolomonMan is on a distinguished road
Default Clutch Issues....
All,
Got a 2007 Saturn Ion with 133K on the odometer. About a month or so back had to have myself towed home from the bank (first time since I bought the vehicle with 6 miles on it) after pressing on the clutch it went straight to the floor.
Got out looked on the ground and fluid was on the ground and fluid was pretty much gone in the reservoirs. Never had any problem shifting prior to that incident and honestly been a very good vehicle. Also no brake issues just prior to break down or honestly much in car history except pads and a set of rotors.
Anyways I get in my garage over Christmas break and I fill the reservoir a little and have my son press the pedal and its clearly leaking out of the lines coming from master cylinder to "line connection" block toward the front of the car (before it splits to the brakes calipers/cylinder etc)...
Upon closer inspection I found two lines, one rusted severely and thru in a spot the other similar rust pattern but not thru,...I mean the lines looked great except for 4-6 inch area....pressure test prior to removal verified leak.
So I bought a 60 inch line split it in two and used the original connectors (taken from old line) with a new flare end I did on each...I hooked it all up...no big issue...and poured a decent amount of fluid in the reservoir...
My power brake bleeder was in my other garage so I went and got it...upon return couple hours later I found the reservoir empty and fluid all over ground....First thought was I forgot to tighten my new lines down...Nope all tight and no leaks apparent even upon pouring more fluid in reservoir.
So I added some more and see if I could "find" the leak (son was away at friends)
So my problem appears to be leaking mid back of engine and falling down the side of engine block to the trans/engine split...but does not appear to be lines there.
Is there a way I can test the power clutch throw out bearing separately?
I have concern that I could have blown out the lines and then messed up the throw out bearing assembly and am just seeing residue from original line issue and the rest is just dripping down inside the clutch area?...I would be surprised but I was surprised I lost fluid...I am also wondering if the slave reservoir is somehow releasing fluid...looking for other peoples experience here...I know I may just have to jack the car up and look thru wheel well area and have my son press the clutch/brakes a few times.
And finally what is the proper bleeding process...I assume as my brakes may have sucked in air I should bleed all brake calipers/cylinders starting in rear passenger going farthest to closest (ending up at driver front)...then do I do the throw out bearing last?
The last power clutch I bled was on an old 1968 Ford Panel truck...bleeding power clutches is not something I have done much on.
Thanks for the help,
Chris
Add to SolomonMan's Reputation
Rate the quality of this post and help SolomonMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SolomonMan is offline   Reply With Quote
Old 01-07-2019, 08:27 AM   #2
SolomonMan
Default Re: Clutch Issues....
All,
*bump*
Anyone have any experience with this clutch Assembly?
Especially bleeding air out of it?
Found a you tube video on it but my part appears a little different.
thanks,
chris
Old 04-04-2019, 01:56 PM   #3
freemancomputer
freemancomputer has a spectacular aura aboutfreemancomputer has a spectacular aura about
Originally Posted by SolomonMan View Post
All,
*bump*
thanks,
chris
These cars are pain to bleed. I ended up with a top bleeder that goes over the cap and hooks up to a hand vacuum pump that i picked up from harbor freight. Takes 5 min and you get the clutch and brakes.
Add to freemancomputer's Reputation
Rate the quality of this post and help freemancomputer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freemancomputer is offline   Reply With Quote
Old 04-06-2019, 08:55 PM   #4
Samtherecordman
Samtherecordman is on a distinguished road
Samtherecordman's Avatar
2007 ION-3 Quad Coupe
You should never use vaccum pump or bleeder on these clutches.
Contrary to most other cars, these Ion clutch will bleed with transparent flexible brake line bleeder kit, a empty transparent jug, 1 or 2 bottle of clutch fluide (use brake fluid works), screw driver, needle nose. That is it, you don't need anything else.
Bleeding is simply by gravity, few pumping of the clutch and that is ALL there is to it. So simple, most garage don't have a clue how to do it!
You may have to repeat the process a few times, add some fluide a few time. The old oil collected in the jug may have contaminant in it, so you may not want to reuse it in the system.
Follow this video and you will have success.
https://www.youtube.com/watch?v=wXbOrxWv65Q
If for some reason you allready blown the trowout bearing slave cylinder, than, I hate to say, you will have to take it a part.
Saturn Ion 3 Quad Coupe 3 with Sports Appearance package with Aura Pro Bass Shakers under the front seats, Kenwood Excelon Mono Amplifier and Infinity Kappa Perfect and I'm In Heaven!!!!
Add to Samtherecordman's Reputation
Rate the quality of this post and help Samtherecordman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Samtherecordman is offline   Reply With Quote
Clutch and Gas Issues SlayZombi S-Series Tech 6 11-05-2018 11:47 AM
97 sl clutch issues? marmitage S-Series Tech 6 11-05-2013 06:23 PM
92 SC Clutch Issues DirtymaxDiesel S-Series General 3 03-14-2013 01:14 PM
Clutch issues myklarson S-Series Tech 3 04-23-2010 10:04 AM
Clutch issues on 97 SL2 knickia S-Series Tech 9 08-19-2008 08:19 PM
