Old 02-11-2014, 12:14 AM   #21
AndreasChen
AndreasChen is on a distinguished road
Default Re: Key won't completely turn off stuck at acc
Originally Posted by mariee500 View Post
I went to shut off my car today and the key would not turn past acc. In the manual it says to pop the cover and stick your finger up inside the hole under the steering wheel and push some plunger thing and manually bypass some lock thing. Well I did not feel any plunger thing, I did get allot of goo on my finger, but I hit something obviously because my key turned completely off. Does anyone know if this is a fluke thing or if its a problem that needs to be fixed?
http://www.saturnfans.com/forums/sho...d.php?t=183467
02 Saturn SC2, noisy, trying to quiet it down...
Add to AndreasChen's Reputation
Rate the quality of this post and help AndreasChen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AndreasChen is offline   Reply With Quote
Old 12-18-2014, 03:11 PM   #22
sj123
sj123 is on a distinguished road
Hi, this is my first post in this forum, I will explain my problem
2005 Saturn Ion 2 Sedan
Today I started to have problems with the ignition key, this can not turn off the car (key stuck at acc)
I got turn off the engine by pulling out the green cable from the ignition switch (see the video) is this safe?
But the strange thing is that the cylinder does not hold the key, so I can remove the key with the engine running, can it be broken? (see the video)
Youtube: youtu.be/0ZocxapGs6A
What do you recommend?
Change the switch
Change the cylinder
Both
Thanks in advance
Add to sj123's Reputation
Rate the quality of this post and help sj123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sj123 is offline   Reply With Quote
Old 12-18-2014, 03:47 PM   #23
2006 ion2
2007 ION-2 Sedan
Call the dealership, schedule your recall repair.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 12-18-2014, 04:30 PM   #24
sj123
Did it, thanks
Old 12-20-2014, 11:53 AM   #25
DrHicks
DrHicks has a spectacular aura aboutDrHicks has a spectacular aura about
This.
In fact, GM has actually been pretty reasonable about this recall (eventually), even to the point of reimbursing people for towing and other expenses.
But don't worry about GM. The new switch costs them about $10, and takes about 15 minutes to replace.
Add to DrHicks's Reputation
Rate the quality of this post and help DrHicks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DrHicks is offline   Reply With Quote
Old 12-22-2014, 02:03 PM   #26
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Originally Posted by DrHicks View Post
This.
with 1-2hr waiting time for them to get to your car.
I cant complain too much tho, they did do a great job with the service.
after hearing everyone have issues with their ions after the service kinda drove me away a little bit, but had to eventually.
its been almost 2 months since I had mine done, and no problems (other than my rear pass. brakes screaming at me to be changed lol)
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-25-2018, 07:23 PM   #27
well485
well485 is on a distinguished road
I futzed with this type of problem for about a year. I have an '07 VUE and found that after inserting the key, I put upward pressure on the key while turning (either starting or turning off), there is no binding and the key pulls right out without any drag. No money spent, just had to change my mindset while turning the key.
Dave
Add to well485's Reputation
Rate the quality of this post and help well485 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
well485 is offline   Reply With Quote
Ignition Key Stuck, Will NOT Turn or Come Out Quadragin S-Series Tech 5 11-29-2009 09:09 PM
2003 ION 2 Ignition Stuck at ACC nForce Ion Tech 8 11-24-2009 01:54 PM
Battery rundown while on ACC / No start / Can't remove Key bc3tech Outlook General 11 12-08-2008 10:08 AM
Followup: Key won't turn off, stuck in lock. davesaturn Ion Tech 2 05-21-2008 03:59 PM
Key stuck, very hard to remove key from ignition... Actaeon S-Series Tech 7 12-21-2003 01:08 AM
