Old 10-21-2018, 02:33 PM   #21
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default Re: Car will not start after seats removed, help?
As suggested before and still applicable with a different starter, did you try shorting the starter battery terminal connection to the smaller terminal oon the starter? Leave ignition OFF so you won't have the engine startup. All this does is test battery cable connection, ground connection (starter case to engine block and ground connection to battery negative). The starter should run and crank the engine. If you do this, you'll verify the battery connections and starter are fine. This does not test the starting circuit. Performing a starter test can help narrow this problem.
The starting circuit is electronic. Ions were part of GMs ignition switch recall to replace faulty igniting switches. Was this done on your car? The symptoms are all the same, intermittent starting failure with security flashing during starting. Even if the ignition switch was replaced, this doesn't eliminate a possible starting circuit problem. Electronics used in starting circuits can be difficult to troubleshoot because turning the ignition switch to the START position sends a signal to the engine computer to command starter operation. Similar to push button starting, starting is electronically controlled. If you can read wiring diagrams, the starting circuit was posted in other Ion threads or I can repost it again if you can't find it.
The car did have the switch recall done, I verified the day after I bought the car...
Are you wanting me to run at wire from battery positive all the way directly to starter? I did jump across the solenoid and the motor seemed to run but the bendix didn't engage, maybe I needed to jump to the smaller terminal on the solenoid?
My next thought is to check all the ground straps, how many are there under the hood? I know about the one between the left side of the chassis to the block, are there any others?
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
“Stock” is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 10-21-2018, 02:56 PM   #22
Starter test at the starter terminals; jumper across the small starter terminal to the battery connected terminal on the starter. A distance of less than three inches between terminals. Leave the ignition switch OFF.
Old 10-21-2018, 04:30 PM   #23
19boneatock88
2004 ION-2 Sedan
IF the engine turns over, what does this tell us? IF it doesn't?
Jerama- WV
Old 10-21-2018, 06:12 PM   #24
Read post #18 again.
1-If the starter runs and cranks the engine, the starter, battery cables and main ground connections are fine. If not or starter has a hard time powering on, there's a power issue with both battery cables, their connections to starter and chassis/engine grounds.
2-Presuming the starter passes the 1st step above, the problem is pointing to the starting circuit electronics.
Old 10-23-2018, 12:58 PM   #25
19boneatock88
2004 ION-2 Sedan
I got it to start! Sort of...
I wanted to absolutely rule out the battery so I used wife’s car for a proper jump start (couldn’t before due to roommate’s truck blocking garage door), charging the battery for almost 30 min before trying anything, and the car would crank over and start... I did this a few times but never left it running and as soon as I unhooked wife’s car, mine refused to start anymore... I’m guessing it’s a bad battery but could also be bad cables that need massive current to overcome resistance...
The starter I swapped in is also bad, it squeals briefly after the car starts... it was pretty greasy, so the bendix could be a little sticky... it could go away or I could end up having to replace it... I broke the little terminal off the solenoid on the original starter on its way out...
Jerama- WV
Old 10-23-2018, 01:20 PM   #26
If you're in doubt about battery issues, either drive to any auto store selling car batteries and ask them to test your battery or bring the battery to them for in-store bench tests. A battery will have one of three issues - partially discharged and needs charging after a load test, good as is after a load test or dead. AutoZone is nationally a front runner for providing free services for battery and alternator testing. Most moderate priced car batteries, excluding Optima, last around 4-6 years and die.
Old 10-25-2018, 12:17 AM   #27
19boneatock88
2004 ION-2 Sedan
I’ll orobabky try and revive a spare battery that’s sitting in my nonfunctional Redline before buying a new one but a cheap battery from Wal-Mart is like $50 plus core
Jerama- WV
Old 11-28-2018, 02:30 PM   #28
19boneatock88
2004 ION-2 Sedan
I ended up just buying a new battery from Wal-Mart and the car will now start on its own! The only issue is the negative terminal; the threads are stripped and it can’t be properly torqued down... threads in the battery are fine, and the ones on the terminal bolt are definitely gone... can the bolt be replaced or do I need a whole new terminal?
Jerama- WV
Old 11-28-2018, 07:06 PM   #29
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
The terminal bolts are replaceable, and a pair can be had at Walmart for a couple bucks.
2007 Ion 2 Quad Coupe 5-speed manual 180K miles
2007 Chevy Equinox LT 191K miles
2018 Chrysler Pacifica Touring L 27K miles
Add to ruley73's Reputation
Old 11-30-2018, 05:04 PM   #30
19boneatock88
2004 ION-2 Sedan
Thanks, I guess I now have to figure out how to remove the bolt from the terminal...
Jerama- WV
Old 11-30-2018, 11:17 PM   #31
If its a side terminal cable, it should resemble the one below. All GM side terminal battery cables have the heavy insulated cover on the terminal bolt to prevent corrosion forming on battery terminals. The soft rubber can be peeled back some to see the large ring terminal holding the bolt captive. The captive washer holds the short bolt. Grabbing the head of the bolt with pliers or vise grips can make it easier to unscrew the bolt. There's an unthreaded portion of the bolt under the head. Pulling the bolt away from the ring terminal and unscrewing the bolt should allow threads to bite into the ring terminal for removal. Buy the direct replacement bolts from auto stores. They're short to prevent using long bolts from bottoming out in the shallow lead side terminals of batteries. Using a longer bolt will strip the leaded threads and ruin a perfectly new battery - the reason for short bolts.
Old 12-02-2018, 03:37 AM   #32
19boneatock88
2004 ION-2 Sedan
I couldn’t figure out how to get the bolt out so I used an xacto knife to cut the rubber... bolt came out easy enough afterward... I ran a 3/8” bolt through and into the battery, but it was too long... gonna get another one later to properly sort the terminal
Jerama- WV
Old 01-24-2019, 03:45 AM   #33
dssl1
dssl1 is on a distinguished road
dssl1's Avatar
The $50 flooded cell Everstart battery at Wal-Mart with 1 year warranty will only last you just over 1 year. It takes just about 13 months for the water/acid to evaporate out. It's worth paying the $93 for the 5 year warranty Everstart maxx AGM battery. You knew you should have gotten AGM as you mentioned it earlier in the thread.
Add to dssl1's Reputation
Rate the quality of this post and help dssl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dssl1 is offline   Reply With Quote
Any way found to have heated seats come on with remote start? PCweber Aura General 4 11-20-2010 12:42 PM
Remote Start Turns on Heated Seats? ddollhoff 2008 Vue 4 01-22-2010 12:48 PM
remote start with heated seats den98xes Vue General 2 01-16-2009 02:40 PM
remote start & heated seats den98xes 2008 Vue 3 01-11-2009 05:04 PM
Heated Leather Seats, Remote Start, Paint Quality IowaVue 2008 Vue 40 05-28-2008 11:23 AM
