Old 02-16-2014, 03:36 PM   #1
jkembry
jkembry is on a distinguished road
Default Radio stopped working, CW plays
Very strange incident here. the radio in my 2004 Vue stopped working, however the CD plays well. Check antenna connection and it it good. Does anyone know if there ar fuses to be checked? Or, should I just replace it?
Thanks,
Jeff
Add to jkembry's Reputation
Rate the quality of this post and help jkembry reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jkembry is offline   Reply With Quote
Old 02-16-2014, 11:16 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Radio stopped working, CW plays
There is no fuse that would affect only the tuner section of the radio. There is a wire going to a spade terminal on the back of the factory radio. This is a secondary ground that is intended to reduce interference by grounding the chassis of the radio. If this is disconnected, the tuner should still work ok but more interference may be noticed on all but the strongest stations.
Used replacement factory radios can be bought from eBay or your local junkyard for under $50. Just look for the same radio that you have from a 2004-2005 Vue or Ion. If your radio is the base CD player with the orange backlit display, you should consider upgrading to the MP3-capable radio with the teal display.
2007 Ion 2 Quad Coupe 5-speed manual 181K miles
2007 Chevy Equinox LT 193K miles
2018 Chrysler Pacifica Touring L 36K miles
Add to ruley73's Reputation
Old 02-19-2014, 02:01 PM   #3
jco35
jco35 is on a distinguished road
2005 VUE Red Line
Thanks,
Jeff
Hey Jeff,
The same exact thing happened to my wifes 2005 Vue. I just pulled the radio fuse out from the passanger side compartment to reset the radio and it worked like a charm. Give it a go and let us know if it works.
Add to jco35's Reputation
Rate the quality of this post and help jco35 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jco35 is offline   Reply With Quote
2004 Saturn Vue radio stopped working jerryt14 Vue Tech 2 07-11-2012 07:17 PM
radio display not working but plays cds rayc S-Series Tech 1 09-23-2008 07:10 AM
XM radio stopped working... REDLINE_IT Vue General 3 06-28-2008 02:14 PM
'04 Vue Radio stopped working (but CD/MP3 still works) russellhome Vue General 4 01-18-2008 08:03 PM
radio stopped working oldgoat S-Series General 3 08-11-2005 05:24 PM
