Old 08-15-2012, 06:04 PM   #1
Konowl
Konowl is on a distinguished road
Default Adding Steering Wheel Controls
I have the base XE. Great car - stereo is GARBAGE. Going to replace my headunit but need the steering wheel controls to maintain cmoputer control - if I just buy the steering wheel controls, is the hookup for them in the steering column already? So it would just be a matter of hooking them up and doing the TECH2 turn on? I ordered the OP COM thingy and am going to try TECH2 out myself LOL.
Add to Konowl's Reputation
Rate the quality of this post and help Konowl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Konowl is offline   Reply With Quote
Old 08-15-2012, 08:59 PM   #2
bdshaffer
bdshaffer is on a distinguished road
bdshaffer's Avatar
2008 Astra XE
Default Re: Adding Steering Wheel Controls
There is a wiring harness you need for the controls that is not in your wheel. Also, the controls can't be installed on a wheel that didn't come with them.
Add to bdshaffer's Reputation
Rate the quality of this post and help bdshaffer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bdshaffer is offline   Reply With Quote
Old 08-16-2012, 05:40 PM   #3
Konowl
So if I bought a wheel with the controls on, there will be a wire coming out of the steering column that I attached it to ?
Old 08-16-2012, 09:35 PM   #4
bdshaffer
bdshaffer's Avatar
2008 Astra XE
Maybe, depends if the seller took it out or not.
Look at this thread:
http://www.saturnfans.com/forums/sho...d.php?t=140799
and this one:
http://www.saturnfans.com/forums/sho...d.php?t=128135
Old 08-17-2012, 08:07 PM   #5
Konowl
I've read both those threads but didn't get my answer. I'm just wondering if there is some sort of connection coming from the steering wheel that I connect the controls from the wheel to.
Old 08-18-2012, 01:14 AM   #6
romanster
romanster will become famous soon enough
romanster's Avatar
The XE does not have the yellow steering wheel control wiring harness under the airbag. If you buy the controls on their own, you will still need this yellow harness. And they won't fit onto the vinyl XE steering wheel anyway, the posts/clips are in different places. I suppose you can just cut them off and rely on the torx screw to hold them on though. That should be fine.
If you're buying the controls/harness, or a whole steering wheel with controls/harness, it will plug straight onto your existing steering column, no modification necessary. There is already a socket on the steering column. The dealer has to enable the controls with Tech2 afterwards though.
I added steering wheel controls to my XE 5 door, but I bought the leather sport steering wheel from an XR 3 door. It came with the yellow harness and the controls, so after I installed it, the dealer just had to enable them.
When I was putting everything in my XE5 back to stock to trade it in, I wanted to include the steering wheel controls and harness since the XR3 I was getting already had them, but like I said they physically won't fit onto the vinyl XE steering wheel. The vinyl XR steering wheel is different.
Add to romanster's Reputation
Rate the quality of this post and help romanster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
romanster is offline   Reply With Quote
Steering wheel controls Swordfish Astra General 5 01-20-2011 12:01 AM
Steering wheel controls issues TJB Astra General 16 09-10-2010 10:37 PM
For Sale: Steering wheel controls phatfire6 Astra General 3 07-13-2010 09:45 PM
Steering wheel with controls - swap? syncro87 Astra General 7 07-07-2009 06:27 PM
Please help me understand steering wheel controls Robor007 Astra General 7 04-13-2009 09:05 PM
