Old 06-28-2007, 01:18 AM   #1
liamsaturn
liamsaturn is on a distinguished road
Default rust rear doors
Greetings all
92 S series
I am a newbie to the forum as well as to saturns
so far so good, I am impressed with what I have seen except the rust
is there a quick fix for the metal slat/post between the roll down window and the fixed glass in the rear doors
of course all metal is gone at the door jam below the plastic, That I can repair
but I am not familar with the doors
Do I need to replace the doors?
can the slats/post be replaced, fixed?
any cool tricks or ideas???
ThanksLiam
Add to liamsaturn's Reputation
Rate the quality of this post and help liamsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
liamsaturn is offline   Reply With Quote
Old 06-28-2007, 08:53 AM   #2
HStockSolo
HStockSolo is on a distinguished road
HStockSolo's Avatar
Default Re: rust rear doors
Quickest is to replace the entire door including the door hinges (they are easier to bolt/un bolt to the body than the door.)
That piece of frame and that little triangular window are a seperate replaceable part. I got two nice rear doors w/ hinges from a 1995 SL1 from the self-service junkyard. I pulled out those windows and exchanged them with the rusted through ones on my 1995 SW2, and then returned the SL1 doors for a refund.
There are two Torx bolts one on the top and and one on the bottom holding it in. You have to remove the outer door panel to get at the bottom bolt. There are about a dozen torx bolts and the outer rubber trim holding the outer panel to the door frame. Roll down the windows, take out all the bolts, and gently pry the outer panel loose from the trim. Pull the weather stripping back from the top corner of the door to access the upper torx screw holding the top of the window in. Pull the weather striping lose from the channel and then remove the lower torx bolt holding in the bottom of the window. Then just shimmy the window gently out of the door frame.
I would recommend sanding any rust out of the replacement window frame and giving them a few coats of black enamel. They rust from the inside out. The replacements I found one looked rust free before I pulled them out of the door and looked behind the weatherstripping. Also it is a good idea to put a strip of masking tape on the bottom of the frame before you reinstall it--otherwise you will likely grind a bunch of paint off. And you might as well sand and paint any more rusted areas inside the door frame while you have outer panel off.
1995 Saturn SC2 - ST(X)ish
1994 BMW 325i Sport
www.furrin.org
Add to HStockSolo's Reputation
Rate the quality of this post and help HStockSolo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HStockSolo is offline   Reply With Quote
Old 06-28-2007, 09:11 AM   #3
RevoRacer
RevoRacer is on a distinguished road
RevoRacer's Avatar
1994 SW2
I had some rust on my door sills just under the rear doors. I ended cutting out the old and welding in new steel. It was a 2 day project. But it was worth it, because now I can honestly say my 94 is rust free.
Add to RevoRacer's Reputation
Rate the quality of this post and help RevoRacer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RevoRacer is offline   Reply With Quote
Old 06-30-2007, 12:43 PM   #4
JADEDSL2
JADEDSL2 will become famous soon enough
JADEDSL2's Avatar
Location: Sullivan, Missouri, USA, North America, Northern West Hemisphere, Earth, Solar System, Left Galactic Arm, Milky Way Galaxy, Local Galactic Cluster, Universe
1993 SL2
1991 SL2
Greetings all
92 S series
ThanksLiam
Well, I don't live in the rust belt up there, so I have no idea about the slats, as I have NEVER seen any that are rusted through, or even corroded. Mine have lost the clear coat on the paint, which I plan on sanding down and repainting. Now, the door sills, of course, have rusted, and are flaking apart, but I too, am planning on cutting and welding to repair that.
"1G8ZJ5472MZ134321"-my Jaded, I will never forget.
"1G8ZF5594PZ249184"-Trinity, for three are now one.
Add to JADEDSL2's Reputation
Rate the quality of this post and help JADEDSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JADEDSL2 is offline   Reply With Quote
Rust at the bottom of the door frames on both back doors Crazy C S-Series Tech 30 06-10-2012 07:35 PM
Small rust spots rear doors black molding Alan S. Outlook General 1 08-19-2009 07:54 PM
rear window switch on rear doors youngbishop Aura General 4 03-26-2007 11:49 AM
93SL2's back doors windows... pile of rust inbetween? Mistral S-Series Tech 6 06-12-2004 03:57 AM
Rust on Rear Brake Drums bstew0411 L-Series General 8 04-30-2003 10:11 PM
